90 Bronco 5.8l having several issues.
First of all my issues is restart. The first start of the day it starts and runs fine, if I turn it off and don't wait at least 5-10 minutes it acts flooded and is hard to start. Replaced all injectors less than 100 miles ago. Did a normal tune-up replacing plugs, wires, cap, rotor, oil about 500 miles ago. Removed aftermarket chip I had installed thinking it may have been problem but it is still there. Also it sounds beefy but feels gutless when driving. Can't get on it to pass or just pick up speed fast, doesn't allow the downshift or throttle to ramp up. Any help will be greatly appreciated thank you.
on
Any codes?
What is the fuel pressue?
What is the timing set at?
You said it sounds like it's flooding, is it? Are the plugs wet? If they are that suggests the injectors are being held open, but since they were just replaced the cause is an electrical wiring short or a problem with the PCM.
What condition is the exhaust in? Could it have a clogged/melted cat?
@My4Fordtrucks I put headers on, new y-pipe w/ O2 Sensor, with Aero Turbine Muffler. This issue I'm having is recent, exhaust was done 2 years ago and never had any issues. Also I'm not getting any codes.
Any codes?
The following users liked this post:
ford racer 02
1978 - 1996 Big Bronco
11-19-2002 12:20 PM
