Sponsored by: Real Truck
Another 4x4 ?
Old Mar 5, 2011 | 08:11 PM
black01bullitt's Avatar
black01bullitt
Another 4x4 ?
I have searched and I'm tired of looking for it so I'll ask. I have a '01 F-250 4x4 with the 5.4. The axles in the front will not unlock. The 4 wheel drive will work if turned to the manual postion on the hubs. But when turned back to auto it doesnt unlock the axles. It will not go into 4 wheel drive with it in auto though. Any ideas?
Old Mar 7, 2011 | 12:10 AM
V10ZILLA's Avatar
V10ZILLA
Bump............
Old Mar 7, 2011 | 01:34 AM
cartmanea's Avatar
cartmanea
Won't lock and won't unlock sounds to me like one is locked in and the other is locked out when in Auto. Best bet is to try disassembling both and making sure both are in the same position.
Old Mar 7, 2011 | 05:49 PM
black01bullitt
Just went out a jacked the truck up with them in the auto position the pass. axle was turning and the drivers side axle wasnt. Turned the hub to lock then to auto and it stopped turning. Crank truck up and turn switch to 4x4 and the drivers side still doesnt turn and the pass. side locked like it was supposed to. Turn switch back to 2x4 and the pass. side axle stops turning. Any ideas on this. Sorry for all the ?'s as I dont know to much about 4 wheel drive stuff, but you give me a Mustang and I can tear it down and put it back together.
Old Mar 7, 2011 | 06:02 PM
cartmanea's Avatar
cartmanea
That could be just the differential working and putting power to one tire due to drag on the other. Jack the front up, put it in 4wd with the E-brake on and see if either front tire turns by hand when locked and in auto. With the drive line held still, both should turn opposite directions. If both don't turn opposite directions then one of the hubs isn't locking.
Old Mar 7, 2011 | 06:26 PM
black01bullitt
It was in park with the rear wheels on the ground. Would that be the same as having the e brake on? And the pass. side doesnt alway unlock.
Old Mar 8, 2011 | 12:10 AM
cartmanea's Avatar
cartmanea
Ok, that works. It sounded like you has all 4 in the air and were running it to check the hubs, I was specifying to turn them by hand.
Old Mar 8, 2011 | 06:20 AM
black01bullitt
Would that mean both hubs are bad? On already bad and the other on the way out?
Old Mar 8, 2011 | 08:23 AM
cartmanea's Avatar
cartmanea
Sounds like hub issues, not sure if it's a vacuum leak or a mechanical problem though.
Old Mar 8, 2011 | 10:00 AM
2000silverbullet's Avatar
2000silverbullet
I had vacuum leaks in my 2000 where the hubs wouldn't work in Auto nor would they unlock. If by chance they did lock in Auto, they'd never unlock. Once I disconnected the vacuum lines, I never had an issue again. Unfortunately I had to get out to lock the hubs any time I wanted 4wd (oh how lazy I've become), but at least I could engage/disengage the hubs again.
Old Mar 8, 2011 | 10:29 AM
pappy19's Avatar
pappy19
There was another thread on some site that talked about this very situation. I would first make sure that the vaccum hoses are replaced, pretty inexpensive and I recommend the steel mesh variety. Next, there is a special seal inside the hub assembly that needs to be checked otherwise, the auto-hubs won't work.
Old Mar 8, 2011 | 11:22 AM
cartmanea's Avatar
cartmanea
Another good idea is to disassemble the hubs and make sure they are both in the off position initially. Here is a guide: Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
Old Mar 8, 2011 | 12:02 PM
2000silverbullet
Guzzle's page is great, used it a couple times for reference when working on my old hubs.
To clarify my post (I'd edit it but it might get missed). When I disconnected the vacuum lines, I capped them off at the wheel as well as at the T. I tried replacing the lines but that didn't seem to help, so the leak was elsewhere that I didn't care to investigate. I never had issues with my vents/defrost so my hubs might've been shot as well, who knows.
Old Mar 8, 2011 | 08:48 PM
black01bullitt
Thanks for the help guys. I pull the hubs off this weekend and see what I find.
greenman0013
Feb 20, 2017 08:32 PM
fdude64
Feb 1, 2012 06:01 AM
housemj
Dec 29, 2010 08:44 AM
ron01sd
15
Jan 3, 2008 12:48 AM
RA81222
1978 - 1996 Big Bronco
Feb 24, 2004 02:05 PM
