Cab power stays on
Cab power stays on
OK, here's a question. This morning, I found that the power on my 2000 F350 Crew Cab stays on after removing the ignition key and opening the door. All power stays on (i.e. windows, wipers, radio, HVAC). I've searched and found the posts about F150, Explorers, and other small trucks that mention a corroded wiring harness junction located in the driver's door sill. I pulled the sill plate up and seperated the harness enough to see all of the wires. I did not find this color wire on my truck.
Is this the same fix for the SD's as the lighter trucks or is there a different fix?
Help me, FTE...you're my only hope...
OK, I pulled the fuse block down far enough to get to the GEM mounted to the top which was not fun with the clutch petal right in the way. I did not see any evidence of water (and it would have been obvious with the dust on it). I have tried removing the accessory delay relay and there was no change.
If it was bad, would it give this result? Are there any other GEM's that I should look for?
Mike
Mike
Young Skywalker,
Maybe check the (Delayed Accessory Relay). It might be stuck in the hot/on position.
You can simply swap it with one of the other relays in the fuse box to test it. I'm not sure if your 2000 fuse and relay layout is the same as my 2002, but on mine it's relay #306 in the fuse box.
Rick...
Rick...
What happens when you remove the relay? Do the lights shut off? or do they stay on? Did you hear it click (the relay itself)? Did you actually swap the relay with another one that you know works to test the circuit?
I could have been more clear in my previous post. You need to actually swap the relay with a known good one to test the circuit properly.
Rick...
Rick...
Disconnect the battery for 30 minutes or so. I tested resetting mine a few times in the past and 20 minutes seemed to be the magic number so when I need a reset I just go for 30 minutes to be sure.
Maybe disconnect the battery for a reset and prep the column for the ignition switch test while waiting.
Rick...
Rick...
