Sponsored by: Real Truck
99 front add a leaf experience?
Old Mar 5, 2011 | 09:32 AM
IROCKWITHDIRT's Avatar
IROCKWITHDIRT
Recently picked up a 99 F250 4x4 Ex cab 8' v10 pickup. Truck has high mileage, and while seems some general maintenance items have been neglected over the past couple years, whoever owned it prior loved it LOL.
With matching stock 265 75 16's, on level ground, ground to wheel arch peak is about 38" front and 43" rear......... bout a 5" rake. Would like to get a lil closer to level.
Thinking ideally 3" more in the front would be a good place to be. See add a leaf kits advertising 1.5-3" lift.
Not really a truck or 4x4 guy, so kinda new to this stuff. Any advice appreciated. Thanks!
[url=http://img576.imageshack.us/i/imag0281l.jpg/]
Old Mar 5, 2011 | 10:23 AM
mnpowerstroke99duty's Avatar
mnpowerstroke99duty
I have the Tuff Country 2 1/2" leveling kit on my truck and it looks and works great.It really helps when I have my plow on,also keeps the plow push plates from draging through the dirt when offroad.
Old Mar 7, 2011 | 02:29 PM
mwsF250's Avatar
mwsF250
I suspect that you have F350 blocks in the rear.
Mine came with add-a-leafs in the front. The thing rode like a buckboard - almost no suspension compliance in the front. It hurt. Many like that in a truck, I don't.
I threw them away and installed new leaves - Tuff Country EZ rides. This approach addressed old, saggy springs as well.
MUCH better.
My truck came out sitting just slightly nose down with F350 blocks.
Other approaches that won't beat you to death are a shackle lift kit or the Icon mini-spring kit. Both retain stock springs.
Old Mar 7, 2011 | 04:19 PM
BigPigDaddy's Avatar
BigPigDaddy
Sorry, I don't have any experience with add-a-leafs.
However, I will say WELCOME!
Old Mar 7, 2011 | 05:02 PM
mnpowerstroke99duty
If you like the ride it has now,get the shackle lift.The add-a-leaf kits do stiffen up the ride a little bit,but if have plans for a winch or plow they really keep the front from sagging to the ground.I also suggest you get Rancho RX9000X adjustable shocks,they really help smooth out the ride.The great thing is you can adjust them for different loads.Your 99' F-250 should have the 4" blocks in the rear so you don't have to touch them.The newer F-250 came with 2" blocks,because people thought the back was to high.
Old Mar 7, 2011 | 05:43 PM
IROCKWITHDIRT
Thanks everyone! I looked again, and it appears the back does have blocks. They're about 3 5/8" and appear factory.
This place is local, so I'm going to stop by this week and talk to them. http://www.saintlouisspring.com/
Old Mar 7, 2011 | 07:21 PM
BigPigDaddy
You could always put the shorter factory F250 blocks in the back. That should lower it about 2".
86F150302
26
Dec 30, 2016 08:25 PM
Resto
17
Jul 28, 2016 07:15 PM
Scott Jackson
Sep 30, 2015 02:11 AM
rlacan71
13
Aug 19, 2015 03:07 PM
henritrinelli
1978 - 1996 Big Bronco
Jun 30, 2012 09:04 PM
