So i just peeled the foil and insulation of the IC pipe last night and have been paranoid about what is in there since.....does anyone know for sure if it is fiberglass or something worse....I took not precautions respirator-wise
Hahaha, I'm sitting here drinking mine as we type! no worries and good luck...I peeled as much off with my hands as I could, while watching a movie, then relaxed. I know I will be pulling the IC tubes several more times at some point in the future for other mods so idk how much work I want to do getting every little spot of glue off. Plus I plan on painting them at some point. Hope yours goes well...
I'll be painting mine as well, I found it as an 80 yr old gent and his wife were upgrading to a big motorhome, he ordered new in 99, put a camper on and used it for trips from NJ to Michigan, it spent most of its life in a barn !
It was 99.9% perfect, tires were cracked and had scrapes on the fenders from driving under the camper..otherwise, showroom condition, the find of a lifetime, it was my lucky day
I was thinking of doing it today, have heard wd40 takes the goop off, doing at my dads, he's one of the....has the great idea for almost everything,guys so it'll go smooth, gonna subscribe today so I can post some pics
It's like the household insulation. I didn't use gloves because it's too hard to grip the stuff to pull it off. I used pliers for the foil, and paint stripper from Home Depot for the glue and fuzzies. It took two rounds of stripper and emory cloth but it came off. And don't worry about a dent in the tube. It's suppose to be there.
I used a wire wheel on my 4.5" angle grinder. After peeling off the foil itself, the insulation and glue came off in 10 mins with the wire wheel. I would recommend this method.
well i just got the weekend project finished up...plenum inserts w new boots to the spider, hpx, and foil delete. I just peeled the foil and insulation off by hand and threw it back on, i'll get to stripping and painting some other time.
Mike, that looks great! I hadn't considered painting the spider too, I like a lot!
