update on carb prob
I finally found the culprit. It was retarded ignition timing. Turns out the timing marks didnt jive on the damper for some odd reason. I went back and retimed it at TDC then advanced 13 degrees. In addition, I removed the powervalve altogher and put a plug in there. To compensate, I jetted from a stock #66 to #74 with the mix screws 2 turns out. Shooter size is a #31 with 50 cc cam in the #1 position. I have the 4 hole aluminum spacer as well. In the vac secondaty housing, i have the BROWN spring. Jetting on the secondary metering block conversion is a 70. All I can say is WOW! NO off idle hesitation and it pulls very strong. I am very pleased at how well this thing is running! Now, I hope my gas mileage improves as well. My faith in Holley's is restored
regards
Ben
I have the same problem. Do you think the carb-spacer would help?
I've optimized the timing, tried leaner and richer jet settings on the Ed carb and changed pump shot setting. Still, it stumbles just off idle.
First, try advancing the timing right up until you hear slight pinging and then back it off a bit...before you do ANY carb tuning, Ive found that you need to give the FE some healthy advance.
Next, if you have a holley, i would suggest pulling OUT the power valve and compensate by finding out what the STOCK jetting is and then jet UP 8 sizes. for example, if stock jetting is a 67 with a 6.5 Hg powervalve, pull the powervalve out and jet up to say 74-75 on the primary side.
Third, if you have a holley 600 cm, Ive found that a 31 shooter with a 50cc reo pump works well....a smaller shooter gave me a lean misfire and a larger shooter gave me a rich bog
Fourth, If you still have the metering plate in the secondary side, its OK. I chose to pull mine out and drop in a conversion block and modify with jets like the primary side (my personal preference) However, I dropped in a BROWN spring to keep the secondaries from opening early. I DONT need premature opening bec i do a lot of low speed driving and NOT high RPM use (again personal preference)
Fifth, the spacer was added when i put in the REO pump. It called for a 1/4 inch but i put the 1'' to experiment. The open spacer stole my low end (bad for street) but I found a lil more torque (seat of the pants feel) with the 4-hole. All i can say here is experiment; they are cheap!
Lastly, make sure u have good plugs, wires and NO vacuum leaks--as well as an engine in sound mechanical condition!
Remember, these settings were for a holley 600 cfm 1850 so if you have anything other, you will have to change slightly. I hope this helps you some! Drop me a PM if you have further questions
GOOD LUCK
regards
Ben
