Primer Question.
Am I worring about something that I shouldn't be or should I really be concerned about the bare metal from sanding off for the spot welds that wont be seen? The primer wasn't cheep so just want to be sure Im not wasting my money.
Thanks!
All that said, it really depends on how you intend to use the truck, your weather conditions, and where these hidden areas are as to whether or not you should be concerned with coating the areas. In a dry climate, it may coat itself with some benign surface oxide and be fine for years and years. If it's an area that will be wet a lot, then it would be best to coat them with something.
Understsand that it took 50-60 years to become as big a problem as it is now, and there was never the kind of assembly quality or care given to these trucks as we will now that they're restored. You'll need to decide how crazy you want to get with coating the hidden areas. But if you do decide to coat them, I'd exchange the self etch for epoxy. If you're going to do it, do it the best you can.
Epoxy is the way to go.
Just make sure if this is a part to be top coated you cover the epoxy with a fill primer. The epoxy remains somewhat sticky and can load up your sandpaper if you end up needing to scuff it because you waited beyond the recoat window.
Each paint manufacturer and product line can have different recoat/drying windows. Ask for the data sheet while your at the paint store. If they are a reputable dealer they will have no problem printing one off for you.
Good luck,
Rich
For now these should be parts that aren't exposed once welded up. In particular Im talking about the inner cab corner where it welds to the cab and then where the inner is covered by the outer corner.
Ok, I'm planning to take it back and get some epoxy primer on Monday.
The etch primer has its place as well. It's great for bare smoth metal. It has acid in it that etches the metal and gives the primer some teeth to bite into the metal.
With the epoxy you actually don't want the metal real smooth. Run over it with your DA with some 80 grit and wipe it with some prep solvent. You'll be good to go.
Don't forget to ask for the data sheet. It will help you determine the best mix ratio for your application and recoat windows.
Rich
