92 Ranger won't start
Old Mar 14, 2003 | 06:27 AM
msclford's Avatar
msclford
Cranks but won't turn over. It kind of chugs like it wants to start, but won't. Don't really know where to start ...
Old Mar 14, 2003 | 06:33 AM
amp17757's Avatar
amp17757
How many cylinders?? Fuel injected?? Did it run OK the LAST TIME you drove it?? Or did it act up WHILE it was running last time??
Old Mar 14, 2003 | 08:21 AM
Ken00's Avatar
Ken00
Do you have spark and fuel pressure?
Old Mar 14, 2003 | 08:57 AM
black wolf's Avatar
black wolf
check and see if you can here your fuel injectors making noise when you turn your ignition to the on .if not then your fuel pump needs replacement or something and check your battery too
Old Mar 14, 2003 | 11:32 AM
amp17757's Avatar
amp17757
Sorry ... yet another stupid question. ALL '92's were fuel injected. That leads me to suspect the same as a previous reply, fuel pressure.
Old Mar 20, 2003 | 09:51 PM
fireandemsguy's Avatar
fireandemsguy
Old Apr 7, 2003 | 03:19 PM
Jmatteau's Avatar
Jmatteau
I had the same problem with my 92 Ranger. I changed the fuel pump, and that did not work. I had fuel pressure, air, spark, everything it needed but just would not start. What I ended up finding was a relay in the engine compartment on the passenger side by the firewall was going bad. Try to find it, and just move the wires a bit, knock on it, whatever. There are a few over there so just play with them all. There is a good chance that will be the problem. Let me know how you make out....Jay
Old Apr 7, 2003 | 04:26 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Two suggestions, check the EEC relay and give it a shot of starter fluid and see what happens. Stand aside when squirting it in there.
Old Apr 10, 2003 | 11:16 AM
amp17757's Avatar
amp17757
maclford, had any luck??????????
MustangGT221
Sep 10, 2002 11:55 PM
dcexplorer
Sep 4, 2002 04:54 PM
Bull
1978 - 1996 Big Bronco
Mar 19, 2002 10:31 PM
lee
Jan 29, 2001 08:34 PM
Phillip Guidry
Aug 20, 2000 08:31 PM
