Sponsored by: Real Truck
knocking noise
Old Mar 3, 2011 | 08:53 PM
cardinal thunder's Avatar
cardinal thunder
knocking noise
while driveing my 2005 f350 yesterday I heard a loud knock when i let off the fuel. Thought it was a u joint flopping around after looking nothing. Seemed to be coming form the rear end took back cover off changed fluid did not notice any thing wrong while on stand spun tires all seems fine put it back together same thing seems to be coming from right side and only when letoff accelerator
Old Mar 3, 2011 | 09:06 PM
cardinal thunder
anybody have an idea what could have caused this
Old Mar 4, 2011 | 03:53 PM
BareBones's Avatar
BareBones
Gas, diesel, manual, automatic, 2wd, 4wd?
Old Mar 4, 2011 | 04:36 PM
cardinal thunder
diesel 4wd sorry should hae put it in. the post.
Old Mar 4, 2011 | 04:42 PM
cardinal thunder
Unhappy
It is an automatic trans. It is louder at different times. Seems faster and slower depending on speed, really sounds like a u joint. More like a bang than a knock.
Old Mar 4, 2011 | 09:53 PM
BareBones's Avatar
BareBones
If you're in reverse at a good idle and standing on the brake, then you shift into drive while still standing on the brake, does it pop?
77'FORD_man
54
Mar 30, 2013 02:41 PM
tgen17
Modular V10 (6.8l)
Apr 27, 2011 06:49 PM
cardinal thunder
Mar 4, 2011 09:16 PM
clydesdale6
Apr 12, 2010 02:36 PM
Hellbore
18
May 22, 2006 03:10 PM
