Need Help QUICK!!!
Old Mar 3, 2011 | 01:12 PM
AndeyHall's Avatar
AndeyHall
Need Help QUICK!!!
Ok, I was just sitting in stopped traffic on I85 and my truck just shuts off. It would start and then shut right back off. Finally it started back and I just ran it up the shoulder to the nearest exit. Once I got the truck moving it ran fine and hasn't done anything since I got it to where I needed to be. It's throwing a P0102 (pretty sure this is just a ghost code cause my insight is the only one that reads it) and a P2614 which my insight does not know what that is. I did notice that my oil temps have been slipping farther and farther away from my ECT (ranges from 10-15 degrees once the truck is warm). Anybody think the oil cooler could be clogging or am I looking at something totally different?
Old Mar 3, 2011 | 01:42 PM
utjer's Avatar
utjer
P2614 Camshaft Position Signal Output Circuit/Open
Old Mar 3, 2011 | 01:49 PM
69cj's Avatar
69cj
Andy, It would also help if you put your truck specs in your sig.
Old Mar 3, 2011 | 02:03 PM
AndeyHall's Avatar
AndeyHall
Sorry it's because I'm on my phone that they aren't there. If I post from a computer they are.
Old Mar 3, 2011 | 02:08 PM
AndeyHall's Avatar
AndeyHall
03 6.0L F250 Lariat FX4 Crew Cab
SCT X3 w/ GearHead Tunes; Liberator EGR Delete; 4" Strait Pipe from the the cat back (muffler & cat delete); High Idle Mod; Tank Harpoon; Fog Light Mod; King Ranch side steps w/ lights
Old Mar 3, 2011 | 02:09 PM
AndeyHall's Avatar
AndeyHall
And also FICM tune from PHP
Old Mar 3, 2011 | 02:36 PM
AndeyHall's Avatar
AndeyHall
Would this cause random shut offs?
Old Mar 3, 2011 | 02:41 PM
sandrat's Avatar
sandrat
Maybe, but I've never (personally) seen a CMP fail on a 6.0. Only time I ever see it, it's set as a result of a stalling condition, not a cause. Feel free to correct me if someone has seen otherwise, but I only ever see that due to an engine stall.
Old Mar 3, 2011 | 02:44 PM
npccpartsman's Avatar
npccpartsman
It's probably a bad connection or you may have some wiring issues starting to show. Pull the CPS connector and see if it's oil soaked. The only real issue with the CPS is that the o-ring occassionally fails and leaks. The P0102 is also a wire code for your MAF sensor. You might check the area where those two come together and see if there's an issue there. Chaffing is fairly common on the 03's.
sandrat's Avatar
sandrat
Oh and a P0102 is a MAF code. Could be an issue. What's ICP look like when it stalls?
Old Mar 3, 2011 | 02:51 PM
AndeyHall's Avatar
AndeyHall
Insight doesn't read ICP. But the first time it stalled it didn't read the P2614, it was only after the 2nd time. But where do those wires come together at exactly so that I can check for chaffing?
Old Mar 3, 2011 | 02:55 PM
npccpartsman
He's been getting these same codes for 5 months. I agree that the P2614 "might" be from a stall event. I've seen it more than once myself. I'm still thinking he has a wiring harness issue somewhere since he continually has PCM, FICM, and wiring related issues often.
Old Mar 3, 2011 | 03:00 PM
AndeyHall's Avatar
AndeyHall
I believe I agree. Where is the most common places that issues tend to come up?
Old Mar 3, 2011 | 03:32 PM
bismic's Avatar
bismic
Sorta what I have thought (and also said a few times) for months Tim!!
Old Mar 3, 2011 | 03:57 PM
cheezit's Avatar
cheezit
Originally Posted by bismic
Sorta what I have thought (and said a few times) for months also Tim!!
I pretty well covered it too. buy andy went with his "buddy's" advise.
you only need a cam sensor to start not to run.
