Offroad & 4x4
Disk brake conversion on my 78' Bronc
Old 03-03-2011, 10:36 AM
ibleedblue1385's Avatar
ibleedblue1385
ibleedblue1385 is offline
Figured I would post up some pictures of what I've been working on. Too cold out to work on the f250 and the bronco is currently sitting in the barn for the time being.
Anyways last summer i decided to lay down some rubber on a side road. Long story short as soon as I lit them up and the rear kicked sideways BAM sheared off all 5 moser wheel studs and there goes my 37" bogger passing me down the road flying up through the tree tops. First and last time I ever do a burnout with my bronco. Rear axle came down and pretty much destroyed the entire drum brake setup, so here I am.
Disk brake time!
Build is still in progress so I will update it as I go.
Well the wheel bearings were pretty much toast from the axle slamming on the ground so since I needed to remove the backing plates might as well do all new bearings also. Keep in mind my rear axle is a Dana 60 with Ford 9" tubes.
New bearings.
Old 03-03-2011, 10:40 AM
ibleedblue1385
I then ordered some caliper brackets from Summit Racing, cost was around $30 after shipping. Fits 3" OD axle tube and uses Chevy S-10 calipers.
Went to local parts store and picked up some new rotors for an F150. $45 for both of them.
Old 03-03-2011, 11:33 AM
hav24wheel's Avatar
hav24wheel
hav24wheel is offline
en den?
Old 03-03-2011, 11:36 AM
ibleedblue1385
Test fitting brackets:
Old 03-03-2011, 11:38 AM
ibleedblue1385
I picked up some new calipers and pads for a 91' s-10 yesterday. $55
As of right now I need to get .060" turned off of the rotors so that caliper/pad combo will work. Should have that done later today...and pics to follow.
Old 03-03-2011, 11:40 AM
hav24wheel's Avatar
hav24wheel
Are the backs of your wheel studs hex head?
Old 03-03-2011, 01:50 PM
ibleedblue1385
Yes......
Old 03-03-2011, 01:52 PM
hav24wheel's Avatar
hav24wheel
so they R bolts?
Old 03-03-2011, 01:57 PM
ibleedblue1385
Basically. There Moser brand wheel studs.
Old 03-03-2011, 01:58 PM
ibleedblue1385
Calipers & pads. S-10 calipers with 5 1/2" bolt hole center to center.
Area showing where I had to do some grinding to fit them inside 15" rims.
Old 03-03-2011, 04:43 PM
ibleedblue1385
Got the rotors turned - $10.
Drivers side is mounted up and the bracket tac welded.
Old 03-03-2011, 04:48 PM
hav24wheel's Avatar
hav24wheel
Cut the bracket down to keep the whole pad on the rotor.....
Old 03-03-2011, 04:49 PM
ibleedblue1385
yeah i was thinking about taking 1/2" off...
Old 03-03-2011, 04:50 PM
hav24wheel's Avatar
hav24wheel
I think it would be for the best.
Old 03-03-2011, 04:52 PM
jKsled's Avatar
jKsled
jKsled is offline
Nice! won't be long before i'm doing this to mine! Pics make it easy to follow!
Quick Reply: Disk brake conversion on my 78' Bronc
