Loose spark plug
Old Mar 3, 2011 | 05:53 AM
jbarefoot's Avatar
jbarefoot
Loose spark plug
Any of you guys ever have this happen? I put new plugs in and I noticed the one at the back was loose. So yestreday I was doing a compression test and and that same plug was loose again. I know I tightened it when i replaced it.
Old Mar 3, 2011 | 10:30 AM
Harte3's Avatar
Harte3
Not an uncommon problem with some I6s. I had a 170 in a Ranchero and had to tighten the plugs about once per week. I haven't had that problem with any of my 300s.
Old Mar 3, 2011 | 11:50 AM
AbandonedBronco's Avatar
AbandonedBronco
I think it's just engine specific. I've probably seen the same amount of threads for complaints of spark plugs seizing right up (even if put in earlier that week) as I have for spark plugs that loosen up on their own.
Would a little loc-tite on spark plugs have any negative affects?
Old Mar 3, 2011 | 11:52 AM
dustybumpers's Avatar
dustybumpers
2 of my 300's do that. you can tell it's happening, it will flutter as you go down the road. sometimes the 1 truck will go a whole year without doing it, then will do it twice in 1 week.
Old Mar 3, 2011 | 11:53 AM
dustybumpers
I will pretend you didn't write that..........
Old Mar 3, 2011 | 12:02 PM
AbandonedBronco
Lol, that's why I asked. I have no idea on that one. Always better to ask first than try first.
Old Mar 3, 2011 | 12:05 PM
dustybumpers
neverseize is good. sometimes even then, they'll seize. the loosening plug thing is a pia, but you get used too it. noone said the 4.9 wasn't a hands on motor. hehehehehe.
Old Mar 3, 2011 | 07:53 PM
Trilogy's Avatar
Trilogy
At least with my 300 it is the closet plug that does that.
Old Mar 4, 2011 | 09:09 AM
turnofftheradio's Avatar
turnofftheradio
mine did that a few times on almost every plug. i have found that from being loose the beveled edge gets kinda crusty on the head where the plug seats. I cleaned the beveled surface very well and have yet to have another problem with them coming loose.
Old Mar 4, 2011 | 09:39 AM
77h0t_r0d_wrecker's Avatar
77h0t_r0d_wrecker
I've had it happen as well. In fact when I put the fresh (60k miles on the engine and trans) drivetrain in the 86, I was going to pull the plugs on my old engine and I think 3 out of six could be turned by hand.
So yeah, not uncommon
Old Mar 4, 2011 | 04:29 PM
6CylBill's Avatar
6CylBill
Hmmm. I'll have to check my plug.
Yup, still attached.
Old Mar 4, 2011 | 05:52 PM
dustybumpers
NOT THAT PLUG!!!!! he's talkin about his SPARK plug...heheheheheh.
sup Billy Boy...............
ramair428cjxr7
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Oct 31, 2018 01:31 PM
Apocalypse
Jul 28, 2017 01:02 AM
thegreatgate
Jan 5, 2017 07:11 PM
Resendiz
Nov 12, 2015 06:58 AM
jyates2007
Oct 18, 2015 11:24 PM
