Camshaft Diameter
Old Mar 2, 2011 | 07:56 PM
93f1505.0L's Avatar
93f1505.0L
Camshaft Diameter
Does anyone know to diameter of the camshaft in our motors. I'm doing a project for a engineering design class and that would help me out. If someone has a diagram or cad drawing that would help a lot too. Even just a mic. measurement from an old cam would work.
Thanks
John
Old Mar 3, 2011 | 09:30 PM
93f1505.0L's Avatar
93f1505.0L
No one has an old/spare cam they can measure for me? Or maybe somewhere to look or call to get the info I need?
Old Mar 4, 2011 | 12:11 AM
strokin'_tatsch's Avatar
strokin'_tatsch
I have an old cam out in the shop. Are you just wanting the diameter at the bearings or what?
Old Mar 4, 2011 | 07:25 AM
93f1505.0L's Avatar
93f1505.0L
I need the diameter of the shaft itself. Like between lobes. I would think it would be the smallest part of the camshaft. The raw metal part.
Old Mar 4, 2011 | 11:26 AM
strokin'_tatsch
When did you need this measurement? I can get it for you, but it won't be til tonight when I get home from work with a mic.
Old Mar 4, 2011 | 11:44 AM
pjwoolw's Avatar
pjwoolw
This is what little info I had. Hope it helps you out.
DIMENSIONS
Lobe Lift
Intake 6.44 mm (0.2535 inch) max.
Exhaust 6.43 mm (0.2531 inch) max.
End Play 0.051-0.203 mm (0.002-0.008 inch)
Camshaft Journal To Bearing Clearance 0.051-0.165 mm (0.002-0.006 inch)
Camshaft Journals 53,31-53.34 mm (2.099-2.100 inch)
Main Bearing Journal Diameter
Standard 79.139-79.340 mm (3.1228-3.1236 inch)
0.010 Undersize 79.065-79.085 mm (3.1128-3.1136 inch)
0.020 Undersize 78.811-78.831 mm (3.1028-3.1036 inch)
0.030 Undersize 78.557-78.577 mm (3.0928-3.0936 inch)
Old Mar 4, 2011 | 02:40 PM
93f1505.0L's Avatar
93f1505.0L
pjwoolw, that info is useful too thanks.
Travis, tonight is fine, Next week is spring break so I probably won't be doing anything with it for a week anyhow. Thanks for taking the time to do it for me.
Old Mar 4, 2011 | 07:36 PM
strokin'_tatsch
Cool. That gives me a bit of time. Got a welding job in the morning, might get the measurement after that. I forgot to grab a mic on the way to work today.
Old Mar 4, 2011 | 07:43 PM
93f1505.0L's Avatar
93f1505.0L
Ok no problem thanks
Old Mar 6, 2011 | 09:55 PM
strokin'_tatsch
I'm getting 1.430" between lobes.
Old Mar 7, 2011 | 12:30 AM
Muktown's Avatar
Muktown
Just curious but why do you need the raw forged diameter?
Charlie Tee
1983 - 2012 Ranger & B-Series
Sep 14, 2015 06:36 PM
Kev1180
Jul 1, 2015 10:08 AM
bewilder
Feb 15, 2015 10:45 AM
rjasman1974
1978 - 1996 Big Bronco
Mar 8, 2008 04:23 AM
