Alarm shock sensor placement
Old Mar 13, 2003 | 08:19 PM
dbarracuda's Avatar
dbarracuda
I am getting ready to install an alarm in my 77 f-150. Does any one know if putting the shock sensor on the firewall will work or is there a better location? Thanks
David
Old Mar 13, 2003 | 11:05 PM
rebocardo's Avatar
rebocardo
It is better to place the wire running along under the dash, on the harness, left to right, because it helps isolate it from vibrations caused by the truck cooling down. Which get transmitted to the firewall. Under the dash, it will still be sensitive enough to respond to a broken window.
Old Mar 13, 2003 | 11:18 PM
dbarracuda's Avatar
dbarracuda
I am not quite sure what you mean.
"It is better to place the wire running along under the dash, on the harness, left to right, because it helps isolate it from vibrations caused by the truck cooling down"
I was considering the firewall on the inside of the truck. The shock sensor is just a little box that you bolt somewhere.
"Under the dash, it will still be sensitive enough to respond to a broken window."
So are you saying just someplace under the dash except on the fire wall? Sorry I am so slow.
Thanks
David
BIGTRUCKBIGRV
Aug 26, 2020 02:38 PM
brian42
Oct 27, 2016 05:38 PM
Sleepyguy
Aftermarket Products
Oct 5, 2016 02:09 PM
TXHillCountry
Jun 26, 2008 03:55 PM
