how to test an injector?
Old Mar 2, 2011 | 12:03 AM
Lil Red Sled's Avatar
Lil Red Sled
how do i test an injector. i know you can test it with a noid light to see if its got electricity but is there a way to test if its squirting fuel? my cylinder 8 has spark. il take the plug wire off and it will run the same. i need help quick.
Old Mar 2, 2011 | 07:38 AM
subford's Avatar
subford
Well here is one way, see the attached PDF.
Not sure where I got this information, maybe on this site.
File Type: pdf
Old Mar 2, 2011 | 08:55 AM
deeznuts822's Avatar
deeznuts822
That's some good info there
Old Mar 2, 2011 | 10:37 AM
drjoe171's Avatar
drjoe171
Definitely NOT recommended and may not even be possible with ford but with bosch injection, we'd pull the injector rail out, aim them at on old towel, an pull up on the air plate that feeds fuel to the injectors.
If they all sprayed the same, we'd put them back in.
If some sprayed and some squirted, well, then we'd clean them in a hand crank pressure cleaner made for them.
Old Mar 2, 2011 | 01:49 PM
subford's Avatar
subford
Here is how to clean or rebuild them:
Ford Fuel Injection » Fuel Injector Cleaning
Old Mar 2, 2011 | 01:56 PM
ExtrmZ's Avatar
ExtrmZ
the only real way to test if theyre working properly is to put them on a flow bench, but if its only one youre questioning, take it out, and hook up some voltage, the spray should be a nice even ionization of fuel
jstihl
56
Jun 10, 2016 11:22 PM
therigwelder
Nov 22, 2014 03:14 PM
bebeard
Aug 21, 2011 05:35 AM
danielwd
1983 - 2012 Ranger & B-Series
Jan 2, 2011 10:18 PM
bkcowboss
23
Feb 15, 2008 05:46 PM
