I have a 97 powerstroke. I have stage 1 injectors, a modded 17 hpop, and a dp tuner chip. I was recently on my way home and it made a loud clunk and started blowing white smoke everywhere. Truck will barely stay running and is running very rough. I was told to remove plugs on injectors one at a time and did so and all it changed was it turned smoke from white to black. Any info would be greatly appreciated.
this happened to me, i got a deffective nozzel upon initial start up after doing my 2s and it still ran, extremely skippy but the way it injected fuel was on the out side of the bowl in the piston so it combusted very loud. raw diesel is white, does it smell like diesel or is it oil?
i guess it could be the turbo but no oil is leaking anywere that is visable. the local international shop said injector. that is clays thought as well. smoke was white on the way home and idling is more of a grey/black and smells burnt to me. the amount of smoke even at idle is unreal. i am going to pull injectors tonight. is making clattering noise as well. i am hoping it is not the bottem end of the motor still running good oil pressure. no anifreeze loss and high egt. starts right up and no codes per my AE. thanks
Lots of white smoke and a knocking sounds is common when a nozzle lets go.
But cracked, split, or broken nozzles are very rare to begin with.
If it was turbo, you'd see the wheels chewed up or feel excessive play and it wouldn't necessarily make engine noise, just pass oil out the exhaust and smoke at idle.
Pushrod might be the culprit, too.
Only way to know is to pull the injectors and look at the nozzles. If none appear to have chunks missing, then they need to be cleaned really well to examine for hair line cracks running vertical up the nozzle's side.
ok i have pulled all injectors O'rings and tips look fine to me any ideal what else it could be? eventhough the injectors look ok could they still be causing the problem. thanks
thanks for all the help guys. DZL JIM you nailed it i got some scotchbrite and cleand the tips really good and sure enough hair line crack running from one side up over the top and clear down the other side. man that crack was hard to find. injectors only have 2/m so they are sending new one free of charge. thanks again for all the help.
sorry jiveturkey, you can barely see the crack with naked eye. The tip had to be cleaned with a scotch brite pad to even show up. The best I can tell you is it was a hairline crack that went from the copper washer on one side up to the tip and all the way down the other side. It was very hard to find.
