289 overbore max
Old Mar 13, 2003 | 07:54 PM
66 Ranger's Avatar
66 Ranger
289 overbore max
A friend offered me a 66 289 block 'free for hauling it off'. It's been bored .040 oversize. What is the recommended max overbore for this engine? I know it's probably been discussed before in this forum but this is the first time I've checked in here. I'm usually in the FE forum. Thanks for the responses.
Old Mar 14, 2003 | 11:49 AM
TorqueKing's Avatar
TorqueKing
289 overbore max
I've seen racers get away with .060" overbore, but not for street driven engines, it's cutting way too close to the water jackets on a stock block, and you'd see a lot of overheating with constant use. 040" is usually the maximum safe bore for Windsor blocks, with the exception of the new Dart Iron Eagle blocks, which can take up to 4.185", and I've heard the Motorsport block goes up to 4.125".
Old Mar 15, 2003 | 12:35 PM
Quantrex's Avatar
Quantrex
289 overbore max
Take the block and have it sonic checked. That will tell you for sure how big you can go. I've seen several 289's taken to +.060"; some have problems, some don't. Be sure you use a torque plate when boring and honing.
69supercj
Oct 21, 2013 01:56 PM
69supercj
Oct 21, 2013 10:27 AM
IDI guy
22
Mar 3, 2013 11:25 PM
z537z
Mar 10, 2006 06:02 PM
trinogt
Feb 19, 2003 09:57 AM
