Rust Removal
Old Mar 3, 2011 | 02:22 PM
BACAGrizz's Avatar
BACAGrizz
Are you sure it rust and not moss or lichen?
Looks like a good start though. Good luck with it.
Old Mar 3, 2011 | 02:31 PM
taylor90's Avatar
taylor90
Yeah it's got some moss on the front but a good but of rust too
Old Mar 4, 2011 | 12:37 PM
AXracer's Avatar
AXracer
IMHO the best, if you have the money is to have it soda blasted or walnut shell blasted by someone who does classic cars and hotrods regularly and comes highly recommended by actual customers. First stop would be a local high end classic restoration or hotrod shop in your area for a recommendation. Failing that check with the counter guys at your largest local automotive paint and body shop supplier. Get several recommendations from different sources if you can, one or two names will likely keep popping up. It is definitely better to haul your parts 100 miles or so to someone good than let the local tombstone engraver or brick building cleaner loose on it because they are local or cheaper. A good blaster should clean the parts after and prime or rust preventive coat them for you. Freshly blasted parts will start rusting from handling or just sitting in a couple days.
4xFordFreak
Mar 3, 2013 07:45 PM
66gpw
55
Jan 1, 2013 12:09 AM
RobertNooy
Garage & Workshop
Apr 8, 2008 09:26 PM
Boss_358
Paint & Bodywork
Aug 18, 2002 08:20 PM
