Trailer running lights
Old Mar 1, 2011 | 05:52 PM
whitewhale's Avatar
whitewhale
Question Trailer running lights
Gremlin in my dads truck('03 250 6.0L reg long bed). Running lights don't work on the trailer. Checked for power at every connection I could easily find. No power going back. Fuse is fine(#38 IIRC), I have power at the fuse. Wondering if someone knew what wire I need to probe closer to the fuse box or if there is another fuse to check? No elec. brakes either but I'm going to fight one battle at a time. Thanks in advance, Mike
Old Mar 1, 2011 | 05:55 PM
whitewhale's Avatar
whitewhale
Running lights on truck work fine, it's just the trailer ones don't
Old Mar 1, 2011 | 10:10 PM
Benchwrench's Avatar
Benchwrench
check for a switch, alot of truck guys will wire the trailer running lights on a "courtesy" switch.
This is how I like my truck wired too. When on the road, it's the truckin' thing to flip the trailer lights a couple times after passing and getting flashed to acknowledge it's safe to go back in the lane.
Old Mar 2, 2011 | 06:35 AM
whitewhale's Avatar
whitewhale
No switch, he's had the truck since it was brand new. Everything is stock on this truck. He had to replace the RV plug once(backed into a snow bank), got a replacement directly from Ford.
Old Mar 2, 2011 | 09:34 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
How about the relay ?
Old Mar 2, 2011 | 09:53 AM
teppler's Avatar
teppler
Have you tried checking voltage at plug? Google "7 wire RV plug diagram" for diagram..
Old Mar 3, 2011 | 02:21 AM
Cowboy65's Avatar
Cowboy65
According to the electrical schematic fuse #38 feeds two relays in the power distribution box (located under the hood): 1) trailer back-up lights & 2) trailer marker lights. I would start by making sure that power is getting to the marker lights relay and that it is functioning properly. If the relay is working OK then start tracing the wiring going to the trailer plug (brown/white).
The following link will provide you with a PDF of the electrical schematic.
https://www.fleet.ford.com/truckbbas...bb_pdf/203.pdf
Old Mar 3, 2011 | 06:39 AM
whitewhale's Avatar
whitewhale
Didn't realize there was a relay. I'll check it out this morning, thanks guys
RJG1987
Nov 20, 2016 12:48 PM
Culvert
Nov 10, 2016 09:31 AM
aaronlaaron
Apr 25, 2016 11:24 PM
Roosterhuntin
2009 - 2014 F150
Feb 28, 2015 06:59 PM
V10man
Mar 16, 2014 06:07 PM
