Sponsored by: Real Truck
Trailer running lights
Old Apr 17, 2016 | 03:35 PM
aaronlaaron's Avatar
aaronlaaron
Hi all I have a 2005 f350 6.0, my trailer running lights aren't working. I have check fuses and replaced the fuse panel but still no power. I am thinking of running a wire from the truck tail lights to the plug anybody see any problems with this idea?
Old Apr 17, 2016 | 03:47 PM
1979 Ford's Avatar
1979 Ford
Take your multi meter or light tester and check the plug first at the back of the pickup first. I could very well be a bad plug.
Old Apr 17, 2016 | 04:37 PM
aaronlaaron
Already done that I got no power at the wire that feeds the plug. Brown-white I believe is the running light wire.
Old Apr 17, 2016 | 07:00 PM
dscabra's Avatar
dscabra
Had a similar problem and it turned out to be a fuse in the block under the hood. I don't recall which one it was though.
Old Apr 17, 2016 | 08:47 PM
ligito's Avatar
ligito
Loose wires at connector, Bad auxiliary battery etc.
Old Apr 17, 2016 | 10:13 PM
Sam I Am's Avatar
Sam I Am
Trailer light fuses are on a separate circuit on mine and the fuses are located under the hood.
If it were me I would avoid cutting into the truck wiring and fix the trailer light circuit instead. The "problem I see with the idea" of splicing into the truck lights is that if there is a dead short you could introduce the same fault into the other light circuit.
Then you get to fix 2 problems. If you don't have time to fix it right the first time, do you have time to fix it twice?
Old Apr 17, 2016 | 11:10 PM
aaronlaaron
Your right Sam I am, I'll try and test it at the back of the panel at the relay
Old Apr 25, 2016 | 07:00 PM
ligito's Avatar
ligito
Mine was tested at the fuse under the hood and determined to be a bad circuit.
Then, it was discovered to be the auxiliary battery was bad and was causing the trailer running lights to malfunction. I replaced the battery (Ford did, you can't even see it) and then the circuit was good.
Old Apr 25, 2016 | 11:24 PM
aaronlaaron
problem solved!
The loom had rubbed through the wire about 10" after the conecter under the hood. Right where the cable sheild starts.
Glad I found it!
Pavin2
Dec 3, 2017 06:58 PM
snaponprofile
All Things Towing
May 31, 2013 06:50 AM
fast68
1997 - 2003 F150
Apr 27, 2009 12:32 PM
squigler
1997 - 2003 F150
Apr 1, 2009 06:56 AM
jonney_boy
1997 - 2003 F150
Nov 20, 2005 05:42 PM
