2002 No-Start, Update and Solution
Old Mar 1, 2011 | 02:49 PM
cgl's Avatar
cgl
For those who have helped me out, thank you. The original thread is located here...
https://www.ford-trucks.com/forums/1...placement.html
In short, back in January, my 2002 7.3 died while idling. It wouldn't restart for some time then started acting normal for a day. The next day it would not start. I ordered AE from Clay, after he wouldn't allow me to replace what I thought was a bad IPR. After receiving AE, I realized Clay was correct. My issue was not IPR, CPS or Battery related.
After weeks of troubleshooting, ohming every wire I could find, trialling a good IDM and ohming every wire I could AGAIN.... I could not shake my P1667 code and no start/dying issue. My problem ended up being a broken connector on the PCM. A new PCM and she's as good as new.
Old Mar 1, 2011 | 03:01 PM
PaysonPSD's Avatar
PaysonPSD
Glad you found the problem Rich. Perseverance pays off. Thanks for posting what the problem was. Makes me fell better about havig a spare PCM in my truck.
Did you find the broken pin stuck in the female connector? Just curious.
What pin was it?
Old Mar 1, 2011 | 03:38 PM
cgl's Avatar
cgl
It was frustrating to say the least. I feel the best thing I can do is share my experience with others.
Unfortunately, the pin was not broken on the external side of the connector. Best I can assume it was PCM pin # 96. Strangely enough, I was getting the P1667 with or without the IDM connected. It was definitely affected by hot/cold and vibration which is a classic sign of a broken solder joint (or moisture intrusion).
There are a lot more tests I would have liked to perform but I needed the truck back on the road.
Old Mar 1, 2011 | 04:30 PM
PaysonPSD's Avatar
PaysonPSD
P1667 - CID (Cylinder IDentification) Failure
PCM Pin 96 - Cylinder Identificaion Output
This is why I wanted the pin number to put these two together for future reference.
Thanks Rich and great troubleshooting.
Old Mar 1, 2011 | 07:35 PM
tdpower's Avatar
tdpower
Glad to hear you figured it out and good work on the trouble shooting. You saved yourself some cash.
Old Mar 1, 2011 | 08:22 PM
h2guy's Avatar
h2guy
And a big "Bravo Zulu" for coming back and telling everyone the solution.
Does'nt happen often enough around here.
arkredneck
Mar 22, 2017 07:25 AM
Loftatsea
Apr 26, 2016 12:19 AM
Idaho Hillbilly
Jan 30, 2016 04:03 PM
Bri...111
Dec 21, 2015 09:41 PM
Shake-N-Bake
23
Aug 22, 2012 08:11 PM
