6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
'08 factory navigation
Old Mar 1, 2011 | 01:59 PM
farmb0y's Avatar
farmb0y
I just purchased an '08 F350 with the factory navigation. There was no CD that came with it, and when trying to select the nav option, it says 'Invalide Disc Detected', when there is nothing in it anyway.
The place I bought the truck from says that the CD needs to be in for the nav to work. Is that true?
And which CD should I get, I see there are a number of options on Ebay with different versions.
Thanks for any help!
Old Mar 1, 2011 | 06:07 PM
Bounds-Electric's Avatar
Bounds-Electric
FORD USER
CD has to be in all the time for it to work. Run the most up dated, I will look up # later and put on site.
Old Mar 1, 2011 | 06:27 PM
kane gray's Avatar
kane gray
ford navigation disc items - Get great deals on eBay Motors items on eBay.com!
Old Mar 2, 2011 | 06:25 AM
farmb0y's Avatar
farmb0y
Thanks guys. I was reading through the manual and looking at the ones on Ebay.
Still debating the cost of the most up-to-date CD vs. an older one, are there different features or just the 'most up-to-date' maps?
Old Mar 2, 2011 | 03:27 PM
Bounds-Electric
FORD USER
I keep mine the most updated and if you do not travel alot I can mail you a old one! I have a new one ordered and will get this week!
Old Mar 2, 2011 | 03:57 PM
sideshow's Avatar
sideshow
I have an older map (4p i think). I've only used the navigation a few times, since I just bought the truck a month ago. I got to my destination each time following the arrows, but once I got close, it said guidance not available in this area. is this normal, as you get really close (a number of very short distances between turns) for the voice guidance to go off, or is it cause the map is old. It still found the actual street address accurately, the route turned yellow, and it said "guidance unavailable, use caution, etc"
Old Mar 3, 2011 | 12:49 AM
farmb0y's Avatar
farmb0y
Check your email.
Thanks!
JasonBrod
May 15, 2013 07:39 PM
mountie
Dec 22, 2011 10:08 PM
scrasauge
Mar 9, 2010 07:18 PM
jmarto
2004 - 2008 F150
15
Feb 25, 2007 12:15 PM
cbiggers
Jul 20, 2005 08:34 PM
