rebuilt 460 lifter clacking
Old Mar 1, 2011 | 11:00 AM
76 F-150 390FE's Avatar
76 F-150 390FE
i just rebuilt my 96 460 kb137 flat tops crane 353901 cam sealed power lifters all new everything but crank rods and heads. i had a fried #5 piston was the reason for the rebuild no noise in the motor what so ever. i fired it up broke the cam in had lifters makin noise for a little bit all but one went away untill the 20min mark then it quieted down. changed the oil buttoned a few things up fired it back up and it was back ticking drove it home still ticking now i have about 55 miles on the motor and if you drive it 15 or so miles it quiets down but doesnt go away but if you shut it off and fire it up it comes right back i have marvel in it now but it doesnt seem to be doing anything for it any suggestions? no other noise has plenty of power runs smooth idles smooth
Old Mar 1, 2011 | 01:36 PM
Chadder1313's Avatar
Chadder1313
Are you 100% sure its the valve train? My first reaction would be you wiped a lobe of the cam but, that wouldnt get quieter i wouldnt think. What was your cam break in procedure you followed?
Old Mar 1, 2011 | 03:48 PM
76 F-150 390FE
7qts valvoline VR-1 SAE30 1 bottle of STP supra wear control with plenty of ZDDP fired it up brought it straight to 2K varied it between 2 and 3 for 30 mins and im almost 100% its a lifter im a mechanic by trade my boss thinks is a lifter and i dropped by the machine shop here in town and talked to him and he said the same thing. i would also think it wouldn't run as smooth as it does with a wiped lobe
Old Mar 1, 2011 | 04:25 PM
mark a.'s Avatar
mark a.
Did you check lifter preload when you were putting it together ?
Old Mar 2, 2011 | 06:55 AM
76 F-150 390FE
i did not check preload i never have and never had a problem
Old Mar 2, 2011 | 07:58 AM
Chadder1313
I am under the assumption that as long as, whichever cam you choose, is on the same base circle as stock you dont need to change valvetrain components unless you have valve to piston clearence issues or you need springs. With that being said Im guesing you did mill the heads? Always, always check lifter preload because it will save you from tearing back apart twice. Im wondering if something isnt to tight? Or it could be a lifter that just isnt doing its job.
Old Mar 2, 2011 | 10:47 AM
mark a.'s Avatar
mark a.
Most all if not all aftermarket cams do not use the same base circle, so you must at the least check lifter preload. There is no way to know for sure unless you check it. All top end machining processes (milling, valve seat work, reground valves, etc) will all effect push rod length and preload as well as adding aftermarket speed parts. This is not a process that should be overlooked in engine building.
Old Mar 2, 2011 | 10:56 AM
76 F-150 390FE
i had the heads milled 2600 miles before the rebuild due to what i thought was a head gasket problem but was actually a toasted piston/rings putting condensation into the crank case no noise after reassembly. would preload cause this problem? the fact that it goes away when it feels like it has me leaning towards a lifter that wont pump up and if it does pump up it looses prime when the truck is shut off
Old Mar 2, 2011 | 02:55 PM
mcdonaldm's Avatar
mcdonaldm
the ticking is probably going away because the engine is warmed up and everything has expanded a bit to take away the slack (for want of a better term) in the valve train (much the same reason why you have a gap on solid lifter applications). on the 460's, Ford used a non adjustable valvetrain setup, so any changes to the valvetrain require either longer/shorter pushrods or shimming/milling of the pedastals to get the correct lifter preload back. also changing the cam will require the same thing.
Rgds
Mike
68murc
Aug 11, 2015 05:15 PM
djjoshuad
6.7L Power Stroke Diesel
25
Jan 24, 2015 11:30 PM
jbancroft
Jan 20, 2014 09:13 AM
normalmike
Nov 6, 2013 11:48 PM
broncndrt
69
Jan 29, 2006 02:06 PM
