HID HEADLIGHTS / ENGINE STUTTER
Old Mar 1, 2011 | 10:12 AM
CASTMASTER's Avatar
CASTMASTER
I recently had HID headlights installed on my 05 Diesel Excursion. When traveling and 60 to 75 MPH and I turn on the lights I experience a momentary stutter in the engine. This does not occur at lower speeds. I assume this is because of an excessive power drain on initial activation affecting the computer. Can anyone advise? I am preparing to leave on a 1400 mile road trip soon.
Old Mar 1, 2011 | 02:32 PM
aklim's Avatar
aklim
What mods do you have?
Old Mar 1, 2011 | 02:52 PM
jasonodsky's Avatar
jasonodsky
Just a minor and kind of annoying observation here but why not just turn the lights on when you get going instead of waiting for when you need them? Just my knitpickery.
Yes, I understand you want to know why and how to fix it. I hope someone else can chime in with actually helpful info.
Old Mar 1, 2011 | 04:05 PM
CASTMASTER's Avatar
CASTMASTER
Thanks
Thanks I think I found the answer. It seems the PCM feeds from the driver side battery and initial power requirement to turn the HID's is sufficient to cause a power drop and affect the PCM. I am told power should be hooked to the passenger side battery as well as ensuring all grounds are good.
Old Mar 1, 2011 | 04:10 PM
aklim's Avatar
aklim
I have HID lights and have set them up on the passenger side and also driver side. Never had a problem either way. Do you have any modifications to your truck?
Old Mar 1, 2011 | 05:06 PM
CASTMASTER's Avatar
CASTMASTER
This is my first Ford Excursion. Always wanted one and finally was able to swing it. I have had it a month. I got it a month ago out of south Texas with 55k on it. The only mod I have done was have a premium sound system with amp installed.
Old Mar 1, 2011 | 05:15 PM
aklim's Avatar
aklim
Sometimes the HID lights can cause issues with the ECM. People have complained that this is an occurrence with DP-Tuner's chips which are way more sophisticated and might need a little better handling. So maybe your cables are running too close to the ECM.
Old Mar 1, 2011 | 07:42 PM
CASTMASTER's Avatar
CASTMASTER
Thanks for the info. It goes back to the shop Thursday and I will make them aware of the PCM / HID wiring proximity.
Old Mar 2, 2011 | 02:56 AM
wallz's Avatar
wallz
You are also saying that tou have a premium sound system put in. Have you tried to turn on the lights with the sound system off? Maybe you just have a good amount of draw already.
Old Mar 2, 2011 | 10:21 AM
bcrewcaptain's Avatar
bcrewcaptain
If the HID's turn on surge is enough to cause the power to drop enough to cause the engine to surge/stutter, you have other issues in the charging system.
I would suspect possibly interference from the ballast as much as anything else.
Does it do it every time? only turn on and not when switching off?
Cheap kit?
at highway speeds you should be putting out close to max from your alternator, and even the stock diesel alt should be more than enough to handle that plus most systems.
Old Mar 2, 2011 | 11:05 AM
Snowseeker's Avatar
Snowseeker
I have read before about the HID's causing problems in the diesel trucks. The fix everyone kept mentioning was grounding everything good including the HID box.
aklim's Avatar
aklim
Cheap kit?
Don't most HID systems take LESS energy to run than conventional headlights? I thought that the initial surge was lower too. If so, and he has a charging system problem, he might also have a battery problem
Old Mar 2, 2011 | 11:08 AM
bcrewcaptain
with a decent kit, well installed, the turn on surge will equal the standard bulbs, once they're fired, the power drain is a lot lower. The cheaper kits tend to leak rf/suffer from poor grounding, so relocating/grounding will normally help.
Old Mar 2, 2011 | 09:02 PM
CASTMASTER's Avatar
CASTMASTER
Thanks to all for the input. The problem only occurs above 60mph. I will try turning on the headlights with the sound system off. Truck goes back to the installing shop Thursday morning as I leave for Florida Friday night. I will make sure all input is shard with them. I used to wring this stuff out on my own when I was younger but no longer have time to do so. If the shop cannot remedy looks like I'll be breaking out the multi meter.
Old Mar 2, 2011 | 11:14 PM
duck fan's Avatar
duck fan
Because racetruck
It is a common issue with the diesel Ex and F250/F350. Switching the power to the pass side battery is the appropriate fix. Its well documented.
Tank2009
2009 - 2014 F150
Dec 9, 2016 01:44 PM
Tank2009
2009 - 2014 F150
Dec 9, 2016 01:05 PM
09f250v10
Sep 4, 2015 06:19 AM
mynetdude
Aftermarket Products
Aug 8, 2014 05:42 AM
VONxRUBENxLA
Nov 28, 2011 07:35 AM
