Seals and Bearings
Old Mar 1, 2011 | 06:30 AM
ragphoto's Avatar
ragphoto
Seals and Bearings
I need to replace my rear axle seal in automatic 69 f100. I know its pretty straight forward. Can I get my axle out without a puller?
I am also replacing the front driver side wheel bearings. Do I need a press to get the old ones out and new ones in? Or can I tap em out with a punch?
anything else Im not thinking of?
Old Mar 1, 2011 | 10:26 AM
bmuhlbach's Avatar
bmuhlbach
For a hand made slid hammer you can turn your drum around and put the lug nuts on loose and use that for a slid hammer.The front wheel bearing pull out. the race you would need to tap out.Also you would need a inner seal and the races are in the drum or rotor.New bearings would have new races so you can see what they look like.
