A/C help
Old Feb 28, 2011 | 09:03 PM
harley3348's Avatar
harley3348
A/C help
This is a two question post, both refer to my a/c unit.I have a 2002 7.3 PSD and my clutch turns if the a/c unit is on or off??? Also, the two tubes on the top of my a/c unit under the hood are covered with ice after any use with the truck.
Can anyone help.
Old Mar 1, 2011 | 04:17 AM
stuart1's Avatar
stuart1
The clutch may be seized.
If the compressor is turning constantly the system is freezing.
Unplug the compressor connector and see if it stops turning.
Old Mar 1, 2011 | 05:45 AM
harley3348's Avatar
harley3348
A/C help
Thanks, I will give that a try.
Old Mar 1, 2011 | 06:20 AM
projectSHO89's Avatar
projectSHO89
Keep in mind that the A/C compressor is supposed to operate in most HVAC modes. Check your owner's manual for details.
If the clutch hub isn't seized to the pulley, then the most likely failure is either a cycling switch that is stuck closed or, perhaps, a mischarge.
Old Mar 1, 2011 | 06:39 AM
stuart1's Avatar
stuart1
Yes but it should still cycle.
Old Mar 1, 2011 | 09:02 AM
harley3348's Avatar
harley3348
A/C help
Thanks for the info but can you please explain in laymen terms as I know nothing about these a/c units and Ford will charge me much too much to fix it.
Harley
Old Mar 1, 2011 | 06:04 PM
projectSHO89
...not if the switch is stuck closed.... Supposed to, but it won't.
If it's hot enough outside, it will run continuously. Unless the OP is in the southern hemisphere, that shouldn't be a problem this time of year.
captcruz
Jun 3, 2016 05:21 PM
granadojl
Jul 12, 2010 05:54 PM
JTdesert
13
Aug 9, 2004 12:49 PM
oldiron
May 26, 2004 10:13 PM
big block power
Aug 2, 2002 01:42 AM
