Alarm light on dash
Old Feb 28, 2011 | 08:45 PM
guitarpicr's Avatar
guitarpicr
Alarm light on dash
Anybody hooked up the alarm lite on the dash, & can this piece be pried up to get to the wiring without removing the dash ? I have the light there but it doesnt work.
Old Feb 28, 2011 | 09:05 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Are you talking about the THEFT light?
If so, there is constant 12v power on one side of the socket already. All you have to do is make the ground on the other side to get a lamp to work there. I used a self flashing LED but the concept is the same. The connector has a blank spot for the ground wire. If you can find an electronic parts store and purchase the correct MOLEX terminal, then all you have to do it solder it on and shove it into that connector and then run the wire to your switch or whatever you are doing to get that to light.
Here is a progress photo when I was installing an LED in that spot. I later cut the leads after I soldered them to the circuit board. Sorry I don't have a picture of the finished work.
Old Feb 28, 2011 | 11:36 PM
guitarpicr's Avatar
guitarpicr
Thanks Greg-Appreciate the info & pics.
Old Mar 1, 2011 | 11:50 AM
Shake-N-Bake
No problem.
Actual credit goes to SpringerPop for the research to figure this out. I just followed his lead...
Lots of great info here on FTE.
