Defective fuel injectors - replace 2 or all 8
Old 04-28-2011, 11:36 AM
cartmanea's Avatar
cartmanea
cartmanea is offline
5 was a pain, but do-able.
Old 04-28-2011, 12:05 PM
rdunagan's Avatar
rdunagan
rdunagan is offline
id say if he is that far with mileage rev x wont do much. all it does is patches the problem anyways. it doesnt fix it. the problem will come back so if it was me id replace all 8 with stockers until you can do the arp studs. the airdog you can install by yourself. i did it in my dorm room parking lot. not hard at all just need a fuel disconnect tool and a set of sockets. 20 bucks and about 2 hours time for pay about 75-95 p/hr for someone else to do it and it takes them 3-4 hours so that they make money. id rather buy the tools and do it myself and get a tool set out of it
Old 04-28-2011, 12:23 PM
cartmanea's Avatar
cartmanea
Amen to that I'd much rather spend the money on tools than labor, even if it costs a little more. I bought quite a few specialty tools when I changed my gears, but still came out ahead compared to what I see people quoted for 4x4 gear swaps.
Old 04-28-2011, 12:27 PM
brickie's Avatar
brickie
brickie is offline
OT but how did you kill your truck cartmenea?
Old 04-28-2011, 12:39 PM
cartmanea's Avatar
cartmanea
Details here:
https://www.ford-trucks.com/forums/1...led-again.html
Still debating whether to rebuild or not. Too busy with work at this point.
Old 04-28-2011, 09:29 PM
joetech's Avatar
joetech
joetech is offline
I tried the hotshot to no avail. It was worth the 50 for the chance but I knew before I spent the money it wouldn't work. If a component is bad it needs to be replaced.
Old 08-20-2014, 08:14 PM
Davepomrenke's Avatar
Davepomrenke
Davepomrenke is offline
Just my two cents. I just got a set of OEM remanufactured injectors for 1129.00 bucks, going to install myself. Just watch the master tech do it on you tube and go for it. It is not a very difficult job. I just did a new turbocharger, new billet HPOP from Dieselsite, and I pulled my cab last year and did head bolts, EGR delete, standpipe upgrade, new oil cooler, and blue spring upgrade. Just get a good set of swivel head gear wrenches, watch the videos, and go for it and save your self $3000 dollars. just take your time and get a couple of real nice cushions to lay on. be careful not to drop bolts in the motor. YOU CAN DO IT
I BOUGHT AN AIR DOG ($799)FOR MY 1999 7.3. IT LASTED FOR LESS THAN 10,000 MILES AND BURNED UP, STRANDING ME AND COSTING ME A $359.00 TOW. AFTER CALLING THE COMPANY I WAS ADVISED IT WAS A BAD DESIGN FLAW IN THE SEAL BETWEEN THE MOTOR AND THE PUMP WHICH ALLOWED DIESEL FUEL INTO THE ARMATURE. THEY WANT $200 FOR A NEWLY DESIGNED MOTOR ASSEMBLY. ITS STILL HANGING ON MY TRUCK AFTER I RE-INTSALLED THE OLD PUMP. CALL EM AND ASK ABOUT THAT PROBLEM BEFORE YOU BUY AND BEWARE. I FEEL LIKE I GOT THE BIG SHAFT AND WOULD SAY DON'T BUY AIR DOG FUEL PUMPS
Old 01-29-2023, 08:46 AM
Tom Compton's Avatar
Tom Compton
Tom Compton is offline
Stiction
Try Arch oil 9100
Mitch Bellinger
1999 to 2016 Super Duty
12-08-2016 08:45 PM
Colton Haight
13
10-02-2016 12:18 PM
the_auto_tech
01-20-2015 01:26 PM
cutlass
37
09-08-2010 07:51 AM
dcaddi2
11-03-2009 04:42 AM
Quick Reply: Defective fuel injectors - replace 2 or all 8
