Redoing Brake System
Old Feb 28, 2011 | 02:00 PM
Hamburgerfella's Avatar
Hamburgerfella
1972 F100, 302, 3speed manual.....i wanna upgrade to power brakes and replace lines and hoses. Any recommendations on where to get some good parts or setups? Thanks
Old Feb 28, 2011 | 08:01 PM
Talltruck's Avatar
Talltruck
About the best thing you can do for your truck is to pull a set of front discs from a late '70s F150 from the kingpins out. Get the whole setup, booster and all.
As for hoses/lines, replace them with new stuff; the rubber dries out and the steel lines rust. Also replace the master cylinder, they're ridiculously cheap too. Also take a close look at the rotors/pads and replace them if they're worn. It is your brake system after all!
Old Mar 1, 2011 | 10:43 PM
Hamburgerfella
Yeah ill get the disk brakes in the future, thanks
