High Idle 98 Expedition 5.4 L
Old Mar 6, 2011 | 01:03 PM
alloro's Avatar
alloro
Originally Posted by Golflover
For the record, before this undertaking, I did not know specifically what a TB, adapter, Plenum, IAC, MAF or vacuum was.
It's always nice to know that someone was able to walk away with some helpful knowledge from here.
Old Dec 18, 2011 | 02:13 PM
MPDano's Avatar
MPDano
Is there a Diagram of exactly where the OP found his cracked elbow? I too have a high idle (900 from 1500). I was able to get it to lower a little by cleaning the IAC Valve, Throttle Body and MAS.
My Expy is a 97 with the smaller engine (4.6?).
Old Dec 19, 2011 | 01:13 AM
alloro's Avatar
alloro
Originally Posted by MPDano
Is there a Diagram of exactly where the OP found his cracked elbow?.
Check out this thread and the picture in my post #4.
https://www.ford-trucks.com/forums/1...ng-a-part.html
Old Dec 21, 2011 | 07:45 AM
MPDano's Avatar
MPDano
Excellent. I will check it out. Obviously your engine is out but is this the view from the front or rear?
Hmm, I can't even attach or upload a pic?
Old Dec 21, 2011 | 04:42 PM
alloro's Avatar
alloro
The view is from the front with the intake removed. That's the passenger side valve cover you're seeing.
Old Dec 23, 2011 | 03:23 AM
mharring's Avatar
mharring
this may sound stupid, but with the truck running use a section of heater hose to as like a noise amplifier same method as when u put a sea shell to your ear and you hear all the air and not the the actuall noise,put one end to your ear and run that over any area u may think u have a leak, you would aloso be able to hear air bypassin in IAC or possibly your EGR whichshould be closed at an idle. you may wana check that PCV vacum line on the back of the upper intake horn, that sets very close to the firewall and can rub through if worn out by a bit of blow by like me had when it started up its an elbow made of silcone and can deteriorate over time! just a though elimanate any small stuff first!
joedangelo04
Feb 12, 2017 02:08 PM
johnathan merkling
Aug 24, 2016 04:12 PM
troubled1
15
Golflover
41
May 24, 2016 11:14 PM
jcstratt
1997 - 2003 F150
Jan 31, 2006 11:28 PM
