what brake booster will work
Old Feb 27, 2011 | 08:26 PM
andrew's64's Avatar
andrew's64
I have a 1964 ford f100. It has manual brakes and i want to know what year ford trucks i can take a brake booster from that will work on my truck? anyone know?
Old Feb 28, 2011 | 09:00 AM
BigMikeUGA's Avatar
BigMikeUGA
71-79 should work. I've got a '71 on my '65.
Old Feb 28, 2011 | 01:21 PM
andrew's64's Avatar
andrew's64
alright thanks a lot for that info
Old Mar 1, 2011 | 10:25 AM
garbz2's Avatar
garbz2
61 to 64 do not share the same pattern as 65 and up.
There are no direct bolt on ford truck boosters from later 65 and up units.
To mount a later unit you need to rework the steel master cylender reinforcement to accept the wider and taller pattern. Or go with an aftermarket unit form MPB or others.
Garbz
Old Mar 2, 2011 | 03:47 PM
airharley's Avatar
airharley
Follow what Garbz is advising you. I had to order a set of brackets to bolt my booster to the firewall. I think I listed the part numbers in the tech article on power brakes.
Old Mar 3, 2011 | 12:32 AM
nonoodlez's Avatar
nonoodlez
airharley, could you please post a link to that article? I would like to read up on it.
Also, generally does garbz's advice hold for a '66 F250 as well?
Old Mar 3, 2011 | 11:32 AM
airharley's Avatar
airharley
Nonoodlez there are a few people on here that I would trust handing my truck over to repair. He is definately one of them. He is a wealth of knowledge concerning all sorts of topics.
The article can be found under the Articles/Specs tab at the top of the webpage. But here is the link to the article.
Installation of Manual or Power Brakes Disc Brakes in a 1957 - 1964 F100 .: Articles
There is another article for the 65 and up trucks in there as well. Or I believe there is one.
Old Mar 3, 2011 | 11:40 AM
nonoodlez's Avatar
nonoodlez
Great thanks!
The articles links seem to be down right now. They are giving me an:
Fatal error: Smarty error: unable to write to $compile_dir '/var/www/ford-trucks.com/html/article/var/templates_c'. Be sure $compile_dir is writable by the web server user. in /var/www/ford-trucks.com/html/article/third_party/smarty/libs/Smarty.class.php on line 1102
I will try later and see if they are back up...
Old Mar 3, 2011 | 11:59 AM
airharley's Avatar
airharley
You can also search the site to pull it up.
I take that back. It is down when I manually entered it as well.
Old Mar 3, 2011 | 12:23 PM
nonoodlez's Avatar
nonoodlez
See! I wasn't lying!
Old Mar 3, 2011 | 02:02 PM
Customcab's Avatar
Customcab
Not to but in but; my buddy used a 2nd genreation Mustang Brake booster, I'm (havn't yet) installing a 08's Ranger bosster in my 64. just a though & yes; the bracket holds are different; I'm also going to install a Dentside tilt steering column as well. (Yes there will be modification on my steering cloumn; but doable and looks right!).
Old Mar 3, 2011 | 02:12 PM
nonoodlez's Avatar
nonoodlez
So basically what you are saying is that I can pull a booster from pretty much anywhere and the most I will have to do is modify my brackets?
Old Mar 3, 2011 | 02:49 PM
airharley's Avatar
airharley
Yes, I bought a set meant for a 64 Chevy and drilled a set of lower bolt holes to align with my firewall. That was the extent of bracket mods I did.
