Wiring fog lights
Old 02-27-2011, 09:41 AM
snowdog79's Avatar
snowdog79
snowdog79 is offline
Wiring fog lights
I put some nice PIAA 85w fog lights on our '94 Bronco. They are wired in the "normal" manner - fog light switch gets power from the low beam circuit, fog light relay connected to the battery - but I would like them to be able to come on with the parking lights as well and still turn off when switching to high beams. On the newer F150s the fogs work in just this way. The fog light relay grounds through the positive side of the headlight circuit so when the highs are off, the relay gets ground through the high filament, but no ground when the highs are on. So my question is, is there any reason I couldn't get this to work on my Bronco?
Old 02-27-2011, 01:30 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,699 Likes on 1,374 Posts
You could try it. You will have to move the power source for the fog switch from the lowbeam circuit to the running lights circuit(brown wire).
Old 03-19-2011, 12:26 AM
snowdog79's Avatar
snowdog79
Works perfectly. Just installed some PIAA driving lights as well.
ayp77
1999 to 2016 Super Duty
11-17-2023 10:28 AM
Cory Barrow
03-13-2017 01:16 PM
Jesse73iditurbo
19
12-08-2016 01:25 PM
lowlander
2015 - 2020 F150
09-24-2016 12:51 PM
FKNVA
Electrical Systems/Wiring
11-21-2002 07:47 PM
Quick Reply: Wiring fog lights
