351m for a 4x4
Old Feb 27, 2011 | 06:08 AM
rob8210's Avatar
rob8210
351m for a 4x4
My truck is a 79 f250 4x4 with a 351m. I understand it is supposed to have a rear sump oil pan, it doesn't, my guess is a po swapped in a 351m out of a Bronco. Can I convert this front sump oil pan to rear sump, or do I have to locate a motor from a 4x4?
Old Feb 27, 2011 | 08:37 AM
JustBlaze's Avatar
JustBlaze
A bronco would have had a rear sump too so it's probably out of a car. You can just swap to a rear sump but I think you will need a different pickup for the oil pump, not sure if you can spin it around or something.
Old Feb 27, 2011 | 09:15 AM
mark a.'s Avatar
mark a.
You will need the rear sump oil pump pickup & special main bearing bolt that holds the oil pump pickup.
