Well my 2000 F-350 is starting to act up and it's a first. The last couple weeks the speedometer needle has been going from one side to the other 0-100mph. Also the transmission is having shifting issues along with stalling. It will do it for a while then it will stop and return to normal sometimes. I replaced the OSS sensor on the top of the tranny recently with no improvement. Also I get no CHECK ENGINE lights or No O/D flashing lights. I checked for codes and found 720, 603, and 340 Diagnostic Trouble Codes. The Cam shaft position sensor was replaced about 12,000 miles ago for safety concerns. Could a sensor be defective? I hope MY BUDDIES at FTEF can help me get my truck back on the road.
they have you straight...mine was doing the same thing...with out the shifting problems(6spd) cleaned the sensor and still did it a little less...replaced sensor and all has been well...good luck
Well after changing the VSS senor in the rear axle and the OSS sensor on top of the transmission, my crazy acting speedometer/improperly shifting/stalling truck issues still continue. Could the front wheel sensors be a culprit that is being over looked? It all started one day when I took a (hard)right turn and my over sized tires rubbed the leaf springs and minutes after that the problems arose.
Doesn't the computer take readings from three speed sensors(minus the one in the tranny). If they are not close then couldn't that screw up the spedometer. I can see each wheel bearing speed sensor and the rear diff speed sensor with AE. I read somewhere about if they are not all reading the same it will screw things up.
If someone has AE around you you could see if the speed sensors are reading correctly.
I forgot to tell everyone I have a Superlift TruSPEED speedometer recalibrator installed on my truck. Do these units EVER FAIL and if they do, would it create the problems with my truck.
The Truspeed is wired in series with the speed sensor so the truspeed could be causing your problem. Could be a loose conection on the yellow or green wire that puts it in series. The truspeed also needs power. Do you have the install instructions. It would be easy to temporarily disconnect it.
