jack front end when doing power steering flush?
Old Feb 26, 2011 | 05:41 PM
bigtexan99's Avatar
bigtexan99
I'm gonna get to the power steering flush tomorrow.
Reviewing the instructions at Ford Super Duty Power Steering Flush | Superdutypsd.com it says to jack the front end.
Is this necessary? What does it accomplish? The engine will be on when turning the wheels.
Old Feb 26, 2011 | 06:11 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
It just keeps the strain off your pump and wear on your tires. When I did mine I put some sheet metal under the front wheels and it worked fine, just watch your toes lol.
Old Feb 26, 2011 | 06:12 PM
SpringerPop's Avatar
SpringerPop
Ease of movement from lock-to-lock is the best reason to take the front wheels off the ground for this.
However, be careful to not go back and forth too fast, as considerable internal pressures may occur in your steering dampener (if you are so equipped), and it will spit fluid if you're not careful.
For the most part, slower is better in this case.
Pop
Old Feb 27, 2011 | 02:39 AM
twags6's Avatar
twags6
If you're on black top or concrete, its nicer on your steering. If you're on stone, just steer back and forth, back up when done, and kick the stone back into the holes you made.
Old Feb 27, 2011 | 09:00 AM
Waltdog's Avatar
Waltdog
of American machinists
I recently flushed a truck (not mine) and noticed that turning the wheels did not push any fluid up the flush tube however applying brakes would. Seems like when I did my truck both the brakes and steering action where pushing fluid
Old Feb 27, 2011 | 09:19 AM
Waynenap's Avatar
Waynenap
If I'm not mistaken, your supposed to depress the brake occasionally while turning the wheel, lock to lock.
Old Feb 27, 2011 | 10:31 AM
timmyboy76's Avatar
timmyboy76
I didnt have my friends truck up high enough from the ground, and made some nice "marks", on the driveway...gotta get some acid.
Old Feb 27, 2011 | 01:54 PM
bigtexan99's Avatar
bigtexan99
all done!
I saw more fluid come out when pumping the brakes than from turning the steering wheel.
No test drive yet, at 3.50 a gallon I can wait till my morning commute to see if there is any improvement!
