Sponsored by: Auxito
removing carriers
Old Feb 26, 2011 | 11:03 AM
93 mix 'n match's Avatar
93 mix 'n match
removing carriers
im getting two conflicting methods here. im about to rebuild the spiders/trac-lok in my rear end and i was wanting to take the carrier out to make it easier to work on. some of the people i know say i can take it out and put it right back in as long as i put the same amount of shims in on both sides. but good ol pops says i need to reset the backlash and/or bearing preload? so whats the deal. i dont know from personal experience because ive never done this before.
Old Feb 26, 2011 | 06:33 PM
steve(ill)'s Avatar
steve(ill)
backlash and tooth pattern are controlled by pinion and ring gear positon. as long as you dont move the shims, things should not change... but always a good idea to recheck pattern...... If you are building new, and the pattern is off a little, you move shims one side to the other, and the pattern changes some much with respect to original.. Your assuming original is the base line, it cant vary everytime you take it out.
Old Feb 26, 2011 | 10:39 PM
93 mix 'n match
whats bearing preload?
Old Feb 28, 2011 | 08:11 AM
phil6608's Avatar
phil6608
Check this out. There's a hole LOT of good info on the subject.
http://www.pirate4x4.com/tech/billavista/Gear_Setup/
Old Feb 28, 2011 | 10:52 AM
93 mix 'n match
thank you so much!!! ive been looking for that post to bookmark for forever and i couldnt find it! reps for you!
Old Feb 28, 2011 | 11:10 AM
phil6608's Avatar
phil6608
Hey, no problem. And thanks.
I saw that on another site that someone posted the other day so I added it to my favorites list on my PC.
I knew it would come in handy for a lot of people.
Bruners4
Nov 8, 2014 11:48 AM
93 mix 'n match
General Automotive Discussion
Feb 27, 2011 12:43 AM
bassproguy07
Jun 8, 2007 01:40 PM
chrono4
Offroad & 4x4
Dec 18, 2006 04:35 PM
79driver
15
Mar 14, 2004 11:07 PM
