wheel change
Old Feb 26, 2011 | 04:54 AM
skipr's Avatar
skipr
wheel change
I was wondering what year did ford go from inside nubs to outside for there hub caps. I found a set of 16in 5 hole with the outside nubs with ford logo stamped on them
Old Feb 26, 2011 | 07:30 AM
Doc's Avatar
Doc
On the trucks, I think it was 1965. But somebody please correct me if I'm wrong. Are you sure you didn't run across some car rims? Truck bolt pattern is 5 x 5 1/2". Car is 5 x 4 1/2"
Old Feb 26, 2011 | 10:36 AM
skipr's Avatar
skipr
They are 5x5 1/2
Old Feb 26, 2011 | 11:40 AM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
This has come up before and frustrates me because my wheel references don't give a clean answer to the question. The 1965 date is probably correct because the first reference I have that specifically shows external hub cap nubs on half tons is 1966. This has come up before and IIRC Number Dummy had a reference for it. Stu
