1978 - 1996 Big Bronco
Got code reader, where do I start?
Old Mar 7, 2011 | 06:26 PM
Anafiel's Avatar
Anafiel
making progress...
Originally Posted by b4hntn
Of course this is if the air pump is operating.
Kinda had to take a little break in order to address some household issues. I did though check the smog pump and it's functioning just fine. I'll check over the vacuum lines tomorrow (I hope).
Side note. Ordered a set of Taylor wires for the truck, got a set of Autolite 25's, and a MSD Street Fire coil. Did the cap and rotor yesterday.
When I took the old coil off this evening, the post was almost burnt in half. Needless to say, my truck runs just a little better tonight. Can't wait for the wires to get here from Summit...I'll do the plugs then.
Old Mar 12, 2011 | 07:21 AM
Anafiel's Avatar
Anafiel
Finally got a chance to look at my truck again yesterday. Sure enough, there are broken vacuum lines inside the loom. Everything looked fine at the actual connections, but then my truck started throwing a 332 code. I disconnected the vacuum tube from the EGR valve, and the tube fell right out of the loom. I wonder how many other vacuum tubes are broken inside the loom...
I'm going to NAPA today to buy a roll of rubber tubing.
Thanks for pointing me in the right direction, I'll let you know how it goes.
MrFord619
Nov 14, 2016 09:57 AM
animal_friendly
Escape & Escape Hybrid
Dec 13, 2015 07:18 AM
hs981
Mar 11, 2015 08:02 AM
Raidy
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
24
Feb 20, 2014 08:39 PM
jason867
1983 - 2012 Ranger & B-Series
52
Nov 19, 2006 10:43 PM
