is there a way to measure/guage the oil level in the block
Who changes your oil? If it's a place close to home, most of them will check the oil and top off as needed between changes for free.
I've never heard of a gauge to check oil level, but there's lots of stuff I've never heard of. Have you tried calling or emailing one of those shops that converts vans & trucks for those in wheelchairs? This would be an issue that I'm sure has come up with them before. Perhaps they could point you in the right direction.
Is this what you are looking for?
Oil level indicator alarm and fluid level sensor products
ken
14 quarts is a LOT of oil.
An alternative solution, and probably the easiest, is to manufacture a sensor that becomes the drain plug with a detachable wire lead.
It would need to be shaped like a tower so that it would stick up into the sump and give you a warning when the oil drops to, for instance, 10 quarts.
You don't want it to be set too high, like for instance 12 quarts or you would be getting too many false alarms due to the truck moving around as you operate it.
I know that the 2.9 powered rangers 86-89 had a low oil sensor installed on the oil pan which can be bought for about $30. it is basically a float and a reed switch. Aircraft have electrical capacitance sensors for the fuel tanks
but these solutions are all going to need a hole in th pan.
The technology is out there. My '95 525i tells me when I am one quart low. My wife's '07 335i doesn't even have a dipstick. When you change the oil you add the required amount, then read the indication level on the dash. It even works when the engine is running. I think one designed for an oil reservoir would be cheapest.
Maybe some vinyl/PVC tubing to extend the tube (fitted over it?) around a corner to a spot.
Then couple of junker dipsticks brased/welded together into one long one to slide through this cockamamey thing. Should be easy to calibrate by taping them together until you get the length right (before welding) and reading the same level as the stocker did. Then weld together.
