tries to stall
Old Mar 13, 2003 | 08:55 AM
66ford400's Avatar
66ford400
tries to stall
I have a '72 400 all stock except the holley strreet performer intake and holley q-jet replacement 4011 carb. When I first put these puppies on it ran as smooth as glass. It has been getting worse and worse since then. Now it idles very ruff and when I take a turn it tries to stall. Whats wrong?
Old Mar 13, 2003 | 11:03 AM
beartracks's Avatar
beartracks
tries to stall
Mt first guess would be the float level set wrong or some debirs in the inlet (bowl) valve.
Old Mar 13, 2003 | 11:18 AM
79_250RangerLariat's Avatar
79_250RangerLariat
tries to stall
Any vaccum leaks?
Old Mar 13, 2003 | 09:33 PM
1979F150's Avatar
1979F150
tries to stall
I have seen a fuel pump do this before. You may want to put a presure gage on to see if you pump is still good. The car I seen have the fuel pump problem was 1983 mustang 5.0 just for info. I believe it was when he made a left turn it would try to stall,but not the other way.
Old Mar 13, 2003 | 11:38 PM
BentWheel's Avatar
BentWheel
tries to stall
The Holley q-jet replacement carb has a poorly made float that tends to bend up over time raising the fuel level so umm check the fuel level.
udamanbaby
Jan 23, 2017 07:35 PM
davidrozeboom1
Aug 26, 2016 12:34 PM
ts2745
2004 - 2008 F150
Apr 23, 2015 08:53 PM
jonathan_butler
Aug 26, 2007 07:50 PM
madmader
1978 - 1996 Big Bronco
Aug 15, 2005 03:35 AM
