diablo Predator U7165 question
Old Feb 25, 2011 | 08:10 AM
U235a4's Avatar
U235a4
Trailering
<HR style="BACKGROUND-COLOR: #ffffff; COLOR: #ffffff" SIZE=1><!-- / icon and title --><!-- message -->I'm using a friends unit to monitor my EOT and ECT and what I notice is one the engine temp is between 170-180 with outside temps of mid 30's (is that normal or is the thermostat shot). Also the EOT reads *C not *F and it says the EOT is 49*C that would be 121*F after a 20min drive to work. the other part of this when I use my laptop to do live monitoring and set it for F values I see a - # for the EOT.
Thanks for any insite to this.
<!-- / message -->
<!-- controls -->
Old Feb 25, 2011 | 08:42 AM
tex25025's Avatar
tex25025
Doesn't necessarily mean your thermostate is bad. There can be a few variables. Are you running a fairly "hot" tune. Are you just driving normally etc.
That I can't help you with, sorry.
<!-- / message -->
<!-- controls -->
Is there anyway you can get a screen capture of that?
Old Feb 25, 2011 | 01:02 PM
U235a4's Avatar
U235a4
Trailering
I'm not running a tune just all stock.
Yea I'll get a screen cap today on my way home from work and post later
Old Feb 25, 2011 | 07:23 PM
U235a4's Avatar
U235a4
Trailering
ok here is the screen cap as you can see I have two engine coolent temps one about 5*F higher than the other ECT volts, EOT volts and the EOT which is that - number.
Old Feb 25, 2011 | 07:46 PM
tex25025's Avatar
tex25025
That is strange. I hate to say it, but I don't have the faintest idea about that.
Old Feb 25, 2011 | 08:52 PM
U235a4's Avatar
U235a4
Trailering
My only thought is the lower ECT is the real ECT and the higher ECT is really the EOT and the - value EOT is something else like volts. If this is the case I can't complain about the delta. maybe someone else can answer this, is there two ECT temp sensors?
Old Feb 25, 2011 | 08:57 PM
tex25025's Avatar
tex25025
If I remember correctly the volt values for these sensors range from 0 to 5 depending on what the temperature reading is.
Amicus
Apr 7, 2017 02:17 PM
fordtruckrodder
Oct 11, 2016 11:45 AM
fordtruckrodder
Jun 27, 2016 09:02 AM
scottwetzel
Jun 3, 2010 08:02 PM
robertbourque
May 10, 2007 03:53 AM
