Please Help at Whits END!!
Old Feb 24, 2011 | 10:24 PM
85-4X4-6.9F250's Avatar
85-4X4-6.9F250
I have a 95 F350 Crew cab 5.8 (H)code engine
What its doing is missing at speed, lacks power, idle's rough, wont pull itself out of paper bag. NO CHECK ENGINE LIGHT AND NO CODES
What i have done in the last year
Remanufactured long block 08/10
Battery and alternator
plugs
pcv
verified fuel pressure
fuel filter
swaped out to verify ignition controller and coil
Tps switch
distributor
cap rotor and wires
verified that cats are not pluged up
I know this has to have happened to someone else
Old Feb 24, 2011 | 10:41 PM
88n94's Avatar
88n94
You put the remanufactured long block in about 6 months ago. How many miles on the remaned long block? At what point did your problem begin?
Old Feb 24, 2011 | 10:46 PM
85-4X4-6.9F250
bogged down allot if you put your foot in it but was fine if you took it easy after the longblock but now it just poorly runs. got about 5k miles since swap
Old Feb 24, 2011 | 11:03 PM
88n94's Avatar
88n94
I would consider checking the rocker arm to valve stem clearance. Unless you get some easier to try suggestions first.
Old Feb 24, 2011 | 11:39 PM
84-6.9L's Avatar
84-6.9L
Is the timing set right? I know its a dumb question but its worth a look.
Old Feb 25, 2011 | 05:33 AM
smitty5614's Avatar
smitty5614
do you a MAP or a MAF sensor?
95 is probably a MAF check it. my f250 had similar problems and a mechanic told me to check that out. EGR also could cause some of the symptoms.
Old Feb 25, 2011 | 06:18 AM
lightningfan426's Avatar
lightningfan426
It could be as simple as a fusable link, i had bought a ford ranger with one it did exactly what your saying, my mechanic found it and removed it some one jimmy rigged teh fuse box with a paperclip.
nossliw
21
Feb 2, 2015 01:05 PM
Rajczak
Jul 9, 2012 05:46 AM
mitchntx
Oct 2, 2011 05:08 PM
Millheim
22
Sep 18, 2008 05:32 AM
jmccoy
17
Feb 7, 2002 06:49 PM
