trans & diff Identifcation
Feb 24, 2011 | 08:09 PM
Hi , Im new to the forum , was hoping some one could tell me what trans and diffs are under a f350 crew cab 4x4 I bought for parts its a 1991 with 351, trans code is G the axel code is C5 . Is the front axle a dana 60 or 44? thanks for the help
Feb 24, 2011 | 08:35 PM
front is definately a kingpin dana 60 if it's the stock axle. The rear end will be a 10.25 full floater with either 3.55 or 4.10 gears.
Feb 24, 2011 | 08:44 PM
My F250 also has axle code C5
It is a Full Floating Sterling 10.25" Limited slip 4.10 gear ratio.
Trans code, if I remember correctly, G is the C6.
Just look at the dash gear selector.
P R N D 2 1 = C6
P R N (D) 2 1 = E4OD (will have an OD button on the dash right side of steering column).
Front axle is a Dana 60 with King Pins.
That axle alone is worth 1000$!
Alot of people are looking for those, especially with 4.10 gears!
Feb 24, 2011 | 08:59 PM
thanks for the help guys , was hoping it was a d60, didnt see any overdrive button so am hoping its the c6 too.
Feb 24, 2011 | 09:02 PM
No OD button, defenently a C6.
That one is awesome parts truck! Solid driveline!!
Feb 27, 2011 | 01:54 PM
can anyone tell me what a trans code m and axle code f5 is for a 95 f350 4x4?
Feb 27, 2011 | 02:04 PM
Axle F5 is also Limited Slip 4.10 gear ratio.
I can't find my transmission code chart but is it auto or standard?
5 speed manual is ZF5 or if it's auto it's the E4OD. Only 2 trannys those got for those years.
Feb 27, 2011 | 02:11 PM
thanks for the info it is a manual, **** says 1-2-3-4-od
Feb 27, 2011 | 10:53 PM
i am guessing i have a dana 70?or 80? rear axle.
but i found this on cl
1992 F350 Dually, Sterling, 4.10 ratio, has ABS sensor $550
how do i tell which?
Feb 28, 2011 | 01:22 AM
can anyone decode this?
4 10 f5 ta ajh
610460-9
this is the front axle tag numbers on a 95 f350 4x4
Feb 28, 2011 | 09:07 AM
Feb 28, 2011 | 09:08 AM
Quote:
Originally Posted by
IDIDieselJohn
not quite true John. the C6 was an optional trans until 96 when it was finally dropped from the list.
very few were installed though.
Feb 28, 2011 | 09:09 AM
can you tell if it is a limited slip or not?
Feb 28, 2011 | 10:04 AM
by the tag?? open rear. if it was limited slip, it would read 4L10
Feb 28, 2011 | 12:45 PM
i was hoping the f5 was limited slip like the rear axle
