Need a glue
Old Feb 28, 2011 | 07:11 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
From the same thread title in "Garage and Workshop"
Originally Posted by tbm3fan
Yes the tile is on the Carrier.
Not subject to water unless someone is really careless.
I guess it is more free of the steel than the tile but seems close call.
Primer? As in paint? The deck does have a black anti-rust paint on it.
Adhesion promoter? Never have heard that mentioned before.
Old Feb 28, 2011 | 07:13 PM
dustybumpers's Avatar
dustybumpers
You may have to "scuff" the bottom of the tiles before you glue them down. The origional tile glue for those tiles was an asphalt based product.
Old Feb 28, 2011 | 09:34 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The instructions for that glue says it will work over cutback, I don't see why it wouldn't work under it as well...
Old Feb 28, 2011 | 10:38 PM
tbm3fan's Avatar
tbm3fan
Originally Posted by F350-6
When the Armstrong adhesive failed, what was the mode of failure? Did the adhesive come off the pain? Did the tile pop off but leave the adhesive still bonded to the paint? Did the tile start to crack or bubble up?
The adhesive most seemed to have let go of the tile itself as there didn't look to be much left on it after 2 years. Not saying that it was good in the beginning as the glue never seemed to get a good grip on the tile.
Old Mar 1, 2011 | 07:19 PM
F350-6's Avatar
F350-6
If it was originally installed with an asphalt cutback, the solvent content in the adhesive might have helped bite into the tile, the armstrong might not have the correct bite, or the tile may have cured so it's no longer as pliable as it used to be.
I'd suggest you do an "adhesion test" or just try some different adhesives and techniques, like scuffing the back side of the tile. Glue down little samples, let them cure, then tear them up. If the tile pops off the adhesive, or the adhesive comes off the deck while you tear it apart, don't use it. Look for the one that causes the tile to delaminate as you try to tear it apart.
Old Mar 1, 2011 | 09:48 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
There are always industrial epoxies......
You will need help from above if you ever want to remove the tile later.
Navy guys are good with a needle scaler, no???
Old Mar 4, 2011 | 01:07 PM
tbm3fan's Avatar
tbm3fan
Took a close look at the deck and the impression is that the glue separated from itself. Some is on the deck and some is on the tile.
Old Mar 5, 2011 | 09:14 PM
F350-6's Avatar
F350-6
That would be a cohesion issue. Likely from the adhesive being inappropriate for the application (like an indoor adhesive being used in outdoor humidity conditions) or possibly from application errors (glue put on way too thick or tile set in wrong time frame)
cjben
21
Aug 8, 2011 11:56 PM
fred_79f250
17
Oct 23, 2006 12:00 PM
mantta
May 16, 2006 11:59 AM
F15090300
39
Jul 14, 2005 08:51 PM
8996EBBroncos
Jun 9, 2004 01:21 PM
