New CPS died?
Old Feb 24, 2011 | 11:00 AM
Brother Les's Avatar
Brother Les
Originally Posted by hink10
Hi guys,
Thanks for all the input. I went to the dealer and picked up the CPS and put it in today, we'll see if he keeps running. I had already ordered a black CPS from guzzles site so that gets here soon, now I need a spare. I may have a few spares, if in fact, the CPS is not the problem.
I was also pretty low on oil, probably 2 to 3 quarts. I've heard that that can be a problem? While I was at it, I changed my fuel filters and checked the wires that I could see. There was no apparent sign of any chafing on the wires.
I did add some dielectric grease to the CPS before installation. I'm still nervous about driving, there's nothing worse than getting stranded in cold weather and trying to fix your vehicle on the side of the road.
Anyway, thanks for everyone's help, if anyone has more ideas of what could cause this feel free to chime in. I've read some things about the ICP etc. I hope it's not something I have to hunt for. If it dies one more time, I guess it's into the dealer to check if any codes have been thrown.
Thanks again,
Steve
Low oil volume will keep the injectors closed so the truck will not start up. 2-3 qts is not that low.... 7-8 is what will cause a no start due to low oil. (yes I know for a fact )
Old Feb 24, 2011 | 12:29 PM
PaulDH's Avatar
PaulDH
Good info., and nice photos and illustration Ken. Thanks for posting these.
Old Feb 24, 2011 | 08:22 PM
BadDogKuzz's Avatar
BadDogKuzz
Ken I knew I could count on you !! You are just a vast wealth of knowledge. And thank you for sharing some of it. I am saving this one for my book. That and great job on the jig for the dial indicator. Does anyone actually sale one. Good stuff thank you.
Old Feb 24, 2011 | 09:52 PM
Bobbys Big Red Rig's Avatar
Bobbys Big Red Rig
Hope I am not High Jacking. I had my recall done last summer and it went bad in January. The one they replaced was not the original, guy I bought it from had alraedy went thru a couple. When the last one went bad I had just finished pressure washing. At first it cranked and after pulling it into shop to chase down oil leak it would not start back. Mechanic at work had one, replaced the other and it fired up. He was the one I purchased truck from and kept a spare. Told me I should do the same. Noticed one of your replies mentioned moister and decided to throw this out there. Got to get me another spare.
Hey everyone,
I did some searching, but haven't found an answer. I had my CPS recall done last summer, just failed the other day. I replaced on the side of the road with a "new" black spare. Ran fine for a few days, truck just died again today and haven't received replacement CPS yet. Just walked home.
The tach is not moving engine cranks, no start, same as the other day. What are the chances another CPS went out? It has been rattling around the glove box for a few years, that have any effect? I also have a DP-Tuner chip installed, don't know if that could have any effect. I did wiggle the connection to the CPS before I left the vehicle, no luck. Any ideas? I need some quick advice, I am having someone come take me to get a cps, but It's freezing out and needed any input. They are a pain to change with cold hands, thought maybe something else? Has anyone seen 2 go out within a few days? What else might cause the same symptoms, tach not moving etc? BTW, I have a 2003 Excursion with the 7.3.
Thanks,
Steve
Old Feb 24, 2011 | 10:18 PM
woodnthings's Avatar
woodnthings
Thanks for the compliment! Most of what I have learned about our trucks is from other members. I read almost every post and the outcomes. This makes it easier to help others! This site has some extremely knowledgeable members and we all get to learn from everyone's experiences.
You can buy a tool specifically made for measuring the air gap. Look at this Cam Sensor Measurement tool price is $376......which is why I machined my own
Old Feb 25, 2011 | 09:39 PM
BadDogKuzz's Avatar
BadDogKuzz
OH MY GOD !!.... I just fell off my chair no wonder you made your own tool. Well I guess I won't be doing any testing like you did. Luck for me you alread did. That is as much money as AE software. And AE is on my wish list. Will or how will AE let you know if it is a CPS is bad ?
Old Feb 25, 2011 | 09:49 PM
woodnthings
AE will not "see" the RPM signal, so that would be a good indication. It would also throw a code and allow you to see that you have an issue with the CPS.
Old Mar 3, 2011 | 12:55 PM
hink10's Avatar
hink10
Here is an update... I was driving on the interstate the other day and the truck died again, just when it warmed up about 15 miles out. I was near a dealership so I had it towed. Just got a call from the dealership and they said there was a high pressure oil leak, they think it's the injector o-rings. I had told them the history ect., I thought it may be the IPR although he said it's very rare they go out in the 7.3. I don't know that I believe that, I am just hoping the problem is fixed. If I get it back only to die again, I'll be awfully upset. They are looking at about $1000 to replace the injector o-rings. I know I could do it myself for next to nothing, I just don't have the time any longer to do that stuff. I sure don't like the shops, I always get robbed (to put it nicely)! Feel like I should pick up some lube and practice touching my toes if you know what I mean . Oh well, I guess if it's fixed, all is well. At least I'll know the o-rings will be new. I'm going to start replacing all sensors and commonly failing components. I know I now have at least 3 spare CPSs! I will post when all is resolved...
Hey everyone,
Thanks,
Steve
Old Mar 3, 2011 | 01:07 PM
Brother Les
injector o-rings?
The Dealer will be replacing a lot of parts that are not causing the problem. I hope that you and the Dealer have a 'plan B' after you pay for the new o-rings and you are calling him from the side of the road with a dead truck. I guess you can wait 15 minutes and it will start right back up..... again... and again... (IMHO)
I hope that I am wrong and this will fix your problem.... but I don't think that it will.
Old Mar 3, 2011 | 01:34 PM
Brother Les
There is nothing wrong with you CPS it just got water around the o-ring or into the connection. Dry it out and seal it up. And it you would like keep a 'dry' on in the glove box.
Old Mar 3, 2011 | 01:36 PM
Brother Les
Did I miss it somewhere
Have you had the 'codes' read on your truck? Shutting down like that will throw a code.
Old Mar 3, 2011 | 02:15 PM
hink10's Avatar
hink10
Well, I hope it is the problem. As I said, I don't have the time to work on it and now I'm at the mercy of the stealership. I have been having some significant oil usage and the fuel filter was pretty black when I changed it the other day.
Actually, I just called back and had a pretty extensive talk with the service manager. He said the only code was the ICP high or low pressure. I told him that I pulled that plug when the engine died and it looked like there was a bit of oil in the connection. If I recall, that can be a sign of a bad sensor? Anyway, he was going to have the tech check that. He said the motor would not start even after sitting overnight. That may indicate part of an o-ring is missing and can't build pressure. I also mentioned the wiring harness under the valve cover. He said they were going to pull the valve covers and remove the HPX tube and dead head the rails so they can determine where the leak might be. He assured me they wouldn't just replace the o-rings unless they found an injector leak. He also assured me that they would go through everything to find the problem.
To be fair to the shop, they are primarily a truck dealership and do extensive diesel work on everything from F250s and the like to busses and trucks, always have. I would feel much less comfortable if it was at one of the other dealers in the area. After talking with the service manager, I felt a bit better, he explained they have dealt with this same issues on many occasions.
Plan B, kick the guy in the nuts. I am going to make sure they drive it and the problem is solved.
Old Mar 3, 2011 | 02:22 PM
  #28
Brother Les
hink10
I apologize to you.
It is just hard for me to trust "Dealers". It sounds like you have an honest one there.
Old Mar 3, 2011 | 02:27 PM
  #29
sandrat's Avatar
sandrat
! ......which is why I machined my own
Just out of curiousity, how much would you want to make me one? Being a diesel tech, that would be awesome to have on repeat 7.3 CMP failures!
Old Mar 3, 2011 | 02:35 PM
  #30
hink10's Avatar
hink10
I sure hope it works out! I have never had a good experience with dealer service. I will post when all is resolved.
Steve
I apologize to you.
