Small block projection on 460?
Old Feb 22, 2011 | 11:28 PM
glovemeister's Avatar
glovemeister
I found a deal on a used projection setup like $300 bucks including everything, it works too.
b?
Anyway, its for a small block chev putting out 670 cfm. What is stopping me from utilizing it on my Ford 460 with a carb?
Old Feb 23, 2011 | 01:09 AM
Shark Racer's Avatar
Shark Racer
b?
Should be fine, as long as you upgrade the fuel system for the PSI required and don't run significantly more than stock HP.
With a cam and headers, the 460 could easily overwhelm the capabilities of that setup.
Also, you may need to upgrade your alternator output.
Old Feb 23, 2011 | 01:56 AM
glovemeister
Interesting. If I didn't just buy a brand new carb I may look at this option. Any ideas on if I will notice an increase in anything, conversely a decrease?
My understanding is maybe some mpgs like 2 or 3, better driveability, cons are more expensive, more tuning and harder to dial in than a carb.
glovemeister
Old Feb 23, 2011 | 02:27 AM
Shark Racer
I think EFI is easier to dial in than a carb, but the expense is the biggest drawback.
I don't think you'll really see a decrease anywhere, especially in a stock application.
I'd expect better HP/TQ, 1-2 mpg (especially with a non OD transmission), and much easier starts, smoother idle, better compensation for altitude.
Old Feb 23, 2011 | 03:42 AM
Redneck1465's Avatar
Redneck1465
The computer should tune itself with the projection system thats one of the perks of having it.
Old Feb 23, 2011 | 11:53 AM
Franklin2's Avatar
Franklin2
This may the system where you tune it small screwdriver adjustments on the side of the brain box. I think they did have a oxygen sensor option on some of them though.
Old Feb 23, 2011 | 12:51 PM
Redneck1465
That could be Franklin I guess I just took it as a given that it would have an O2 because all of the projection systems I have ever seen have had the O2 but I guess those might be a newer style.
Old Feb 23, 2011 | 01:44 PM
glovemeister
It does vary they have a closed circuit system and an open circuit system. IIRC only one had the o2 sensor.
Old Feb 23, 2011 | 02:00 PM
Redneck1465
Either way Holley has a very nice support staff and manual that help with the tuning. I wouldnt mind finding one for my truck.
Old Feb 26, 2011 | 10:18 PM
glovemeister
I notice that its a 2 barrel setup so for an additional expense may be finding a 2barrel manifold that will bolt up right? Since its for a 2bbl chev that may really complicate things I think. I am curious as to if the fuel pumps I run stock can power this? Also if I get it and it doesn't work I'd assume that holley has lots of parts for a reasonable price?
Old Feb 27, 2011 | 01:36 AM
Shark Racer
They do sell flanges that let you install a 2 barrel carb on a 4 barrel manifold.
Look up Mr. Gasket 1933 as an example.
Old Feb 27, 2011 | 01:56 AM
glovemeister
Yeah I just called the guy he doesn't have it. So I've been looking at the holley commander 950 kits. Summit only has a 650 cfm or 900 and don't know what to get. I'd rather not over cfm it even if I do mod the motor. It would kill any expected gains in mpgs and may even reduce them.
Old Feb 27, 2011 | 05:55 AM
blucollar4xford's Avatar
blucollar4xford
I would say the 900. I believe 460's came stock with 750 or 800 cfm carbs, maybe bigger, I can't remember. But either way, I think 650 cfm would be awful lean on a 460. I'm glad I got factory efi so I don't have to guess and then mess with tuning it, although the projection would probably run a little better...
Old Feb 27, 2011 | 07:41 AM
Franklin2's Avatar
Franklin2
460's did not come with a large carb. I am not sure what size it was, but I am pretty sure it's not over 650cfm. You have to remember these are trucks, not fire-breathing race engines. A low rpm truck engine does not need a large carb to do it's intended job.
