Sticky oil filter
Old Feb 22, 2011 | 07:33 PM
Fifty4F100's Avatar
Fifty4F100
Sticky oil filter
I just got in from changing the oil in my F350. I am having trouble of late getting my oil filter off. Am I only supposed to hand tighten the filter or use the wrench? I have been in the habit of tightening with the wrench, but this time I only moved it a little. I'm getting tired of wearing myself out trying to get it off. I just hope I don't get a drip now.
Old Feb 22, 2011 | 07:45 PM
clintbonnie's Avatar
clintbonnie
Hand snug is all I do.. never have had a problem..
Old Feb 22, 2011 | 07:54 PM
snakedoc's Avatar
snakedoc
x2...........
Old Feb 22, 2011 | 07:56 PM
rocketman2440's Avatar
rocketman2440
I've never used a wrench to put on an oil filter, only to take one off.
Old Feb 22, 2011 | 08:07 PM
F350-6's Avatar
F350-6
Mine always drips a little if I don't snug it up with a wrench first. Just get a bigger filter wrench if you're worried about it not coming off. I bought one from Napa after Dan showed his to us.
My regular heavy duty filter wrench is on the left. The NAPA one that takes a 1/2" extension and ratchet is on the right. In lieu of a ratchet you could use a breaker bar and 6' cheater if need be, but I haven't seen a filter that stubborn yet.
Old Feb 22, 2011 | 10:13 PM
Bonanza35's Avatar
Bonanza35
I make it hand tie then 1/4 to 1/2 turn with wrench seems to work great.
Old Feb 22, 2011 | 10:19 PM
texas5.0's Avatar
texas5.0
Thats what I do to 1/4 turn after hand tight make sure you lube up the top gasket to.
Old Feb 23, 2011 | 07:25 PM
Fifty4F100's Avatar
Fifty4F100
That's about what I did this time. I guess I have always hand tightened as much as I could then went about 3/4 turn after that. I think that's what I've always done with my gasburners. I do have a very weak AutoZone wrench that only has a 10" handle with a adjustable rubber band. I need to get the NAPA wrench if I continue to change my oil.
Old Feb 23, 2011 | 07:34 PM
big poppa's Avatar
big poppa
X2, one of the most important things in putting in a new filter, lube the gasket.
Old Feb 23, 2011 | 07:53 PM
Izzy351's Avatar
Izzy351
I spin mine on until it touches the block, then I turn by hand one full turn. Never had a problem with leaks or taking it off (also by hand). I don't even own a filter wrench. LOL
Old Feb 23, 2011 | 09:46 PM
RedBoat's Avatar
RedBoat
Rather Be Floatin
..............X2...................
Old Feb 24, 2011 | 04:38 PM
Fifty4F100's Avatar
Fifty4F100
Where do you guys get those avitars?
Or better ...where do you get the girls to pose for them??!!
Old Feb 24, 2011 | 05:15 PM
Kwikkordead's Avatar
Kwikkordead
You can't get a better description than this picture.
I use a 1/2 drive breaker bar on mine to loosen it up.
It makes the job single handed in ease of removal.
It is wide enough to spread the load out around the filter so that is simply doesn't slip or crush the filter, even the most stubborn ones.
Here it is at Napa online.
Store Locator | NAPA Online
