Code Meanings-Chilton Book
Old Feb 22, 2011 | 07:15 PM
SideWinder4.9l's Avatar
SideWinder4.9l
Rear ABS-
Flashes 1 Time-This code should not occur
Flashes 2 Times-Open Isolate Circuit
Flashes 3 Times-Open Dump Circuit
Flashes 4 Times/Red Brake Warning Light Illuminated-RABS Switch Closed
Flashes 5-Times-System dumps in 2wd (2wd & 4wd vehicles)-Condition occurs while making normal or hard stops. REAR BRAKE MAY LOCK
Flashes 6 Times-Sensor signal rapidly cuts in and out-Only occurs while driving
Flashes 7 Times-No Isolate Valve Test
Flashes 8 Times-No Dump Valve Test
Flashes 9 Times-High sensor resistance
Flashes 10 Times-Low sensor resistance
Flashes 11 Times-Stoplamp Switch Circuit Defective-Only occurs while driving above 35 MPH
Flashes 12 Times-Fluid level switch grounded during a RABS stop
Flashes 13 Times-Speed Processor Check
Flashes 14 Times-Program Check
Flashes 15 Times-Memory Failure
Flashes 16-16 or more flashes should not occur
Applies to ALL 1987-1996 F-150 trucks-Except 1993-1996 Bronco Models
Diagnostic Trouble Codes for EEC-IV
Code 11-System Pass
Code 12-RPM Unable to reach upper test limit
Code 13-RPM Unable to reach lower test limit
Code 14-Pip circuit failure
Code 15-PCM Read only memory test failed
Code 16-PCM Keep alive memory test failed
Code 18-SPOUT Circuit open or spark angle word failure
Code 18-IDM Circuit failure or SPOUT circuit grounded
Code 19-Failure in PCM internal voltage
Code 21-ECT out of self test range
Code 22-BP sensor out of self test range
Code 22-BP sensor or MAP out of range
Code 23-TP sensor out of range
Code 24-ACT sensor out of self test range
Code 25-Knock not sensed during dynamic test
Code 26-TOT out of self test range
Code 26-TOT out of self test range (E-400)
Code 28- Loss of IDM, right side
Code 29-Insufficient input from Vehicle Speed Sensor
Code 31-PFE, EVP, or EVR out of test voltage range
Code 32-EVP voltage below closed limit
Code 33-EGR valve opening not detected
Code 34-EVP voltage above close limit
Code 35-PFE or EVP above close limit
Code 41-HEGO sensor circuit indicates system lean
Code 41-No HEGO switching detected
Code 42-HEGO sensor circuit indicate system rich
More in the book, just have to find more time......
-Wes
revdave
Jun 7, 2013 03:54 PM
SideWinder4.9l
Jul 30, 2011 08:29 PM
Django92
Jan 19, 2011 05:52 PM
theperson10
1978 - 1996 Big Bronco
Jan 19, 2011 03:53 PM
fjcsmc
1983 - 2012 Ranger & B-Series
Jun 6, 2010 08:23 PM
