motor rebuild
Old Feb 22, 2011 | 12:19 PM
joeyd61's Avatar
joeyd61
motor rebuild
I ran across what i believe to be a 99 7.3 long block (ALL the goodies are gone).It does have forged rods....My question is--will all the goodies off my 03 7.3 fit/work?? i am still trying to locate the serial number, i believe it's supposed to be stamped on the driver side of the block by the oil filter/cooler..no number there on the passanger side there is 804111 stamped and 182584802 (which is the casting number i believe)..The motor is going to be overhauled for a swap.....I just want to make sure thet my injectors,HPOP,valve covers, wiring harness will work....
Old Feb 22, 2011 | 03:43 PM
joeyd61's Avatar
joeyd61
no one?????
Old Feb 22, 2011 | 05:10 PM
woodnthings's Avatar
woodnthings
Yes the block is the same.
The older blocks are kind of hard to read the S/N's. Mine is very clear and easy to read, but I've seen other engines that are not so easy. Depends on how the machined surface has fared over the years.
Old Feb 22, 2011 | 06:10 PM
SkySkiJason's Avatar
SkySkiJason
X2. All 7.3's are basically the same. The longblock in my truck was in an OBS (for a minute...). Everything from your engine should bolt right up.
Trivial knowledge - the holes for the (8) bolts on an '08 bed have apparently been in the frame since '99...
Old Feb 22, 2011 | 06:20 PM
joeyd61's Avatar
joeyd61
What are you up to? There's a few things I'd be sure do while the engine's out!
I am not sure...the motor was a deal so i grabbed it up...right now just a spare. But you never know..1st is get it to a machine shop make sure its buildable..
Old Feb 22, 2011 | 06:22 PM
SkySkiJason
I have a parts motor in case ya need anything. When are ya thinking about doing the deed? I'd invite ya over, but that things tooooo TALL for my garage!! I've had my engine out a couple times now...
(Dalton's an hour away from my howse )
Old Feb 22, 2011 | 06:28 PM
SkySkiJason
Your sig almost describes my build - add forged rods, Mahle pistons, 910 springs, headstuds and its there. I was going for an ultra reliable DD/tow rig thats still plenty of fun to drive. NAILED IT!!!
Old Feb 22, 2011 | 06:30 PM
joeyd61's Avatar
joeyd61
No rush..the 03 is doing great..I am going to BTS in 3/18..the motor will be a slow process.1st buy the kit get everything I need befor starting ..when the time comes all the help I can get will be greatly appreciated...
Old Feb 22, 2011 | 06:35 PM
SkySkiJason
10-4. ENJOY your visit to BTS!!! Lemme know when you're ready, I'd be happy to help.
joeyd61's Avatar
joeyd61
No fare I am on my phone.....yes that is exactly what I want to do
