Intercooler ???
Old Feb 22, 2011 | 10:29 AM
seanlleiker's Avatar
seanlleiker
Intercooler ???
I have a 97 f350 crew cab and I'm looking to put an intercooler on it. I have found a 99 super duty that has the intercooler, tubing and spyder pipe. Is it worth taking the 99 super duty intercooler system and placing it on my 97? How hard would it be to retro fit it to my pickup. Thanks for your help.
Sean
Old Feb 22, 2011 | 10:37 AM
Robbgt's Avatar
Robbgt
This might help you out...Tims I/C Page example
Plenty of guys here have them and can chime in with more info
Good Luck
Old Feb 22, 2011 | 11:10 AM
seanlleiker
Thanks, I will hav3e to sit down and read it.
Sean
Old Feb 22, 2011 | 11:15 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Sean
What mods do you have or are planning to do? Im asking this because the IC is worth with some mods, I dont think that with the stock engine you need an IC.
Is it an early 99 IC?
Old Feb 22, 2011 | 11:20 AM
bens landscape's Avatar
bens landscape
I was looking at a banks intercooler and it looks really cool and looks like it would work well but i dont know the price on it. It also would be cool to build your own kit. I look forward to hearing how you made out.
Old Feb 22, 2011 | 11:31 AM
Robbgt's Avatar
Robbgt
Banks is well made, well engineered, but very very expensive stuff. Most stuff can be had at a fraction of that price. The banks intake spider is also very well made... again very expensive.
Old Feb 22, 2011 | 11:36 AM
seanlleiker
I don't have much done yet. I have a cold air intake, 4" straight pipe, FPR Shim, Stancor GPR getting a TS chip and looking into rosewood stage's 1 injectors. The intercooler is at a good price and figured if it will work I will pick it up and hold on to it.
Sean
Old Feb 22, 2011 | 11:42 AM
Robbgt's Avatar
Robbgt
Sean, with 1's and a TS chip, chances are your EGT's won't really be getting that out of hand (especially if you get a good tow tune) most run fine with 1's and no I/C.... just food for thought. may want to get some mods done, then see what your egt's are doing while you tow/haul whetever you use your truck for. If your egt's are becoming a problem, then you can slap the I/C in there. Just my .02
ALSO before you start modding anything, make sure you get yourself a set of gauges. Pyrometer at minimum. Most go boost, trans temp, pyrp (auto) or just boost and pyro if manual trans
Old Feb 22, 2011 | 11:51 AM
kent521's Avatar
kent521
I have been doing some research there is a kit that is just the plumbing for this application , a buddy of mine bought the kit and got an 03 I/C and put in his 97 The kit was around 250.00 and a I/C out of the junk yard a lot cheaper than a whole I/C kit .
Old Feb 22, 2011 | 11:57 AM
seanlleiker
Can I ask what kit he bought.
I don't think I will ever do any crazy mods, mostly the ones I've talked about. I will wait and see what the mods do first then if I need to i will look for a intercooler setup.
Sean
Old Feb 22, 2011 | 12:03 PM
jchosler's Avatar
jchosler
I put on the same exact intercooler on my 97 and EGT's are def more stable. I would do it for security, something you wont have to worry about
Yahiko
Jul 12, 2012 04:17 AM
nobearsyet
Dec 12, 2010 12:51 PM
ttttmaxx
Feb 16, 2010 12:29 PM
roger99
19
Aug 31, 2008 06:28 PM
Bird Dog
Sep 3, 2007 12:06 PM
